      01-11-2014, 04:06 PM   #1
2014bmwx1
Drives: 2014 bmw x1
New HID on non-xenon
I just installed a 6000K HID kit in place of the halogens. Much whiter and brighter (3200 lumens). No error message. Only problem is that there's no upper cut-off like the projection lights.
I noticed on the new 428i, they don't have projection lights. They use the same housing as for the halogen lights (multi-faceted mirrors), but with a built-in shield above the HID bulb to create an upper limit on the beam of light.
      01-11-2014, 10:51 PM   #2
halfmoonclip
Drives: X1 28i
2014, do you have hi and low beams?
Moon
      01-12-2014, 08:59 AM   #3
Black Flagged
Black Flagged's Avatar
Drives: M2C
post some before and after pics player
      01-12-2014, 09:12 AM   #4
Youpaiyou
Drives: X1
Also, what brand and how much?
      01-12-2014, 09:38 PM   #5
halfmoonclip
Drives: X1 28i
'14, if you've put HID capsules in incandescent housings, I'm glad you're in Vancouver and I'm not....
Moon
      01-13-2014, 08:23 AM   #6
1fastscooter
1fastscooter's Avatar
Drives: X1 Msport 28i LeMans Blue
I was looking at my halogen lamps last night, I think HID's in them won't be as bad, there is a cover over the end that is build into the reflector, it will block the britest point and the little civics with HIDs don't have and burn your eyeballs.
I might see you in Burnaby (metrotown)? I will be up there from Seattle all this week on business, I'll be in the blue M-sport with out of country tags, he he
