      11-17-2013, 05:16 PM   #1
Robocheme
Drives: 2013 X3 28i, 2014 X1 sDrive
Speedometer reads high
I've had my X1 about a month now and I've been suspecting that it reads high. i commute on a freeway and the speed readings seem significantly higher than in my two previous cars (a Prius and an A3). Since I doubt that everyone else started driving faster, I suspected the speedometer on the X1.
I did a test with my Garmin GPS. With my other cars, the Garmin speed matched the car's speedometer within 1 mph. I was able to find a stretch of road where I could keep a nice steady 70 mph on the X1's speedometer. The Garmin read 66 mph.
Anyone else have this problem? Can a dealer confirm this problem and/or can they fix it?
Thanks,
Cliff
2013 X3 28i, Sparkling Bronze, Tech, Comfort, Premium, Cold Weather, Sports, Apps; 2014 X1 sDrive 28i, Cashmere Metallic, Ultimate, heated seats, wood
      11-17-2013, 05:43 PM   #2
Eric5273
Drives: 2014 BMW X1
All BMWs have this issue. They just read slightly fast. No big deal, and nothing you can really do the fix it. Look on YouTube for the Car And Driver review of the X1. He mentioned it in that video.
Better showing too fast than too slow. At least you won't be stopped for speeding by accident.
      11-17-2013, 05:54 PM   #3
Robocheme
Thanks. So that's how they get such good (relatively) gas mileage? So, my 29 mpg is really 29*(66/70) =27.3 mpg?
      11-17-2013, 06:01 PM   #4
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
The speedometer doesn't have to be accurate, but the odometer does. You will of course get better gas mileage if you think you're cruising at 70 mph but in actuality are only doing 66.
      11-17-2013, 06:20 PM   #5
Robocheme
Aren't both the speedometer and the odometer readings based on the same things, the wheel rotation and tire diameter?
      11-17-2013, 07:30 PM   #6
0w40X1
Drives: 2014 BMW X1 s28i M Sport
I use ScanGuage right in front of the speedo that I can't read very well anyway.
It gives me corrected MPH, coolant temp, voltage, and average mpg.
The odometer and the tach are dead on, but those other numbers like miles to go on tank, and mpg (25.5) don't correlate to anything I understand.
I think the 25.5 might be total mpg for the 5500 miles I've owned car, but my Scanguage gives me tank mpg, and reset average mpg for a condition that I can check to improve mpg.
      11-17-2013, 07:59 PM   #7
Twix
Twix's Avatar
Drives: 2011 e91
I've calculated my fuel mileage and it's typically higher than what the computer tells me it is
      11-17-2013, 09:25 PM   #8
0w40X1
That's what I'm talking about. I already know my driving will average about 25+ mpg.
I need to know tank or short average mpg so I can test speed vs mpg, etc.
There may be a way to reset the mpg, but all the data there is irrelevant to my use.
I know the od is accurate so I just divide the gallons filled to the trip od, then, clear trip od for next fillup.
      11-17-2013, 11:26 PM   #9
iride4u
Drives: 2014 X1 35 M-Sport Dinan
If you want accurate speed get a GPS device that shows your current speed.
      11-18-2013, 07:03 AM   #10
cwickberg
Drives: X1 35i MSport Ultimate,
That is the raw data, from there it gets modified by an ECM. You can recode your car to change tire diameters and also change the readout on your speedometer if you want to... It is data manipulation. AFAIW, the odometer is accurate
      11-18-2013, 08:17 AM   #11
iride4u
When this was brought up on the BMW K1200LT forum. Someone said that part of the reason is the consumer laws in some countries. If they were to read slower then your speed and you got a ticket they might be responsible.
      11-18-2013, 08:30 AM   #12
d1saster
Bulgaria
60
Drives: F15 N55 & E93 N51
I have coded the option to show true speed on the cluster. I haven't played with the different tire diameters option yet to adjust the analog speedometer readout.
      11-18-2013, 09:39 AM   #13
ScottMZ3
Drives: 2018 Camaro ZL1, 2019 X5 40i
Wen you code this, where is the true speed displayed? In one of the little displays between the speedo and tach? If so, is it always displayed or can you toggle the display to something else?
      11-18-2013, 09:47 AM   #14
ZIPNBYE
Let's save military ranks for those who earn it!
ZIPNBYE's Avatar
Drives: ...on the Ragged Edge
The P3 gauge (available for some of the BMW models) shows, amongst other things, actual speed. The car's gauge is very optimistic.
When I'd finished with the oem tires on our 135i, I upgraded a little in size (215/245 stock to 225/255, with same sidewall ratio) and have decreased the optimistic speedo / odo readings, as compared with my Garmin. I will be doing the same with my 1M when its stock tires are done this coming summer.
Richard
2013 BMW M3 Individual -- Fire Orange (sold)
2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold)
2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold)
2009 BMW 135i M-Sport Coupe -- Space Grey (sold)
      11-18-2013, 11:46 AM   #15
d1saster
Bulgaria
60
I set it to show true speed. See the attachment where it appears. You can still toggle to display different things.
      11-18-2013, 10:01 PM   #16
Robocheme
Is there someplace where it's explained how you code a car? I'd love a digital readout of speed.
thanks
      11-19-2013, 12:03 AM   #17
d1saster
Bulgaria
60
You need a D+KCAN or ICOM cable. The procedures for setting everything up is well explained at the e90 coding forum. I tried to list most of the options here: http://e84.xbimmers.com/forums/showp...8&postcount=23
      11-21-2013, 07:29 AM   #18
bosstones
Drives: o_0
I've seen this on a number of cars. The speedo reads slightly higher than actually speed. My MCS does this and most of the rentals I've had while TDY do the same.
