10-25-2013, 12:27 PM | #1 |
Likes Cars
Rep 56
ScanGauge question. Real boost or requested boost?
So there is someone who is a particularly satisfied customer (I won't name names) of ScanGauge and it has gotten me thinking.
In my GTI people tried similar products in hope of having an electronic boost gauge, but they never worked, or rather they only worked when requested boost was the same as actual boost. If you had a boost leak in your DV, or PVC or some set of various letters that was causing you to lose 3-4 psi you'd never know from the electronic gauges. The only way to tell was from a mechanical boost gauge, butt dyno, real dyno etc. Does the X1 actually have the sensors such that it can determine actual boost levels? Or are boost leaks perhaps less likely since turbo technology is 6 years older? |
10-25-2013, 04:16 PM | #2 | |
Rep 485
You barely push the pedal, and 5psi shows up which is why town mileage is pretty good for the X1 with N20 2.0 L. On the track I saw about 257 horsepower which is probably slightly high, but it has percent adjustment, so if you dynoed the car you could calibrate your Scanguage. |
10-25-2013, 05:12 PM | #3 |
Rep 1,922
Drives: 2011 e91
I honestly don't think that 257 number is a lie. This 28i car has been consistently tested at 6.2 seconds to 100 km/h, too fast for only 241hp
10-25-2013, 06:45 PM | #4 | |
Rep 485
Driving hard on track it is heat soaked somewhat and the turbo was holding back at 12psi, and that was at 5k ft altitude, but that is where I saw the 257. |
10-25-2013, 08:04 PM | #5 |
Likes Cars
Rep 56
I think my question still remains unanswered...is the boost the actual boost or just what the computer thinks it should be getting?
VW GTI's lack the ability to send actual boost levels via OBDII, the sensors that determine real levels just don't output for some arcane reason. But you'd still get a number on ScanGauge and similar products, just a theoretical number. |
10-25-2013, 08:34 PM | #6 |
Rep 485
Ok, yeah, I don't know, but you can choose MAP or Boost so the map should accurate, and maybe it calculates off the altitude air pressure.
Like the horsepower, I don't need it to be exact number as long as it's consistent. Then, you can use gauges to find out how different situations impact the engine's efficiency. |
