03-16-2011, 10:56 AM | #1 |
Certified
Rep 61
Morse Code?
Hi everybody. I was driving along the road today with no radio on and heard these electronic beeps which sounded like morse code. Very weird. Has anybody else experienced this?
03-16-2011, 11:51 AM | #2 | |
Mario
26
Rep 981
Was there anything on the driver info display? I think low coolant, oil pressure, windscreen wash will also cause an audio tone. Its either that or PS: Come to think of it I have heard a morse type of tone but that was interference between the mobile and the radio, which was on. Did you have any other type of electronic device with you?
"Do or do not, there is no try!" - Master Yoda
"Always in motion is the future" - Master Yoda "Truly wonderful, the mind of a child is" - Master Yoda "There is no passion to be found playing small - in settling for a life that is less than the one you are capable of living" - Nelson Mandela |
03-16-2011, 11:56 AM | #3 |
Rep 90
I know in some Honda's when you have TP (traffic annoncements) enabled it can beep to warn you that it has lost the station for them.
Maybe it's the same in BMW's |
03-17-2011, 09:40 AM | #4 | |
Certified
Rep 61
03-17-2011, 10:06 AM | #5 | |
Rep 77
I have the same noise coming from the radio area, first noticed it when I changed the mp3 CD Disc, a series of quiet bleeps, it went away when I started to play the disc but when I got into the car this morning I heard the same bleeps before I got the car started up or the radio on. It hasn't happened since. May Be a Ghost in the works. |
03-17-2011, 11:08 AM | #6 | |
Mario
26
Rep 981
03-17-2011, 11:41 AM | #7 | |
Rep 77
When there is no disc in the unit no bleeps can be heard when you open the door. |
03-17-2011, 01:27 PM | #8 | |
Mario
26
Rep 981
Have you got the sat nav/ audio option? Ps: I have also noticed that when you take the key out of the ignition, ie the car is switched off completely, a few minutes later there is a soft whine sound which decreases to nothing. It's as if the car goes through some sort of shutdown routine before it shuts down completely. The P light on my auto box switches off only after about 20 min, apparently this is normal.
03-20-2011, 02:52 PM | #9 | |
Certified
Rep 61
03-21-2011, 10:10 AM | #10 | |
Mario
26
Rep 981
