ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
      10-10-2010, 03:59 PM   #1
mhrir
Drives: Very fast
Suspension and brake torque specs
Did a quick search but did not come up with the answer for the Z4M.
What are the torque specs for:
- the two caliper bracket bolts that go into the hub
- the two caliper allen bolts
- the bolts on the lower suspension that are replaced or loosened when adding the camber washers
      10-10-2010, 08:33 PM   #2
dekaliber
Drives: '07 Z4MC, '11 JCW, '18 Z06
Not sure about the first 2, but the bolts attaching the strut to the kingpin are 81 Nm (60 ft-lbs).
      10-10-2010, 11:30 PM   #3
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Do a search on Bimmerfest and you'll find your answers.
Better yet buy a TIS DVD on Ebay.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      10-11-2010, 03:20 PM   #4
mhrir
Drives: Very fast
The best info I could find is:
Caliper guide bolts: 22 ft/lbs
Front carrier bracket: 81 ft/lbs
Rear carrier bracket: 50 ft/lbs
Rotor bolts: 12 ft/lbs
zpost
