ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
      10-06-2010, 12:31 PM   #1
chanzs
Drives: 2006 Z4 M Coupe
Suggestions to cure poor turn-in
I've owned the MC for a little over a month now but I find the turn-in response a little slow. The car rows quite a fair bit before settling down for the corner, adequate for sweeping corners in a road course but rather lacking for autocross or tight twisty canyon sprints. I find it particularly difficult when negotiating quick S-bends as there is too much weight transfer from the excessive body roll.
Anyone here autocross with their MC?
Anyone here with KW V3s that can share their experience? Thks!
2006 Interlagos Blue Z4 M Coupe
2011 Starlight Black Exige S
2011 Montego Blue 323i
1996 Repsol Honda NSR250SP
      10-06-2010, 12:45 PM   #2
The HACK
Midlife Crises Racing Silent but Deadly Class
The HACK's Avatar
1821
Drives: 2006 MZ4C, 2021 Tesla Model 3
Toe-out and/or camber. [/thread]
      10-06-2010, 01:24 PM   #3
esqu1re
esqu1re's Avatar
44
Drives: M Coupe
Auto-X with the M. Slalom kills my time, among other things.
///M Coupe: RPI Scoop, OE Strut, CDV, Volk RE30, SS Brake Lines, Stromung Exhaust
      10-06-2010, 01:30 PM   #4
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
lol... that about says it.
For a quick one, you can also run higher tire pressure up front.
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
      10-06-2010, 07:56 PM   #5
Master Apex
Drives: '17 F80 M3 '07 Z4M '06 E60M5
In my experiment with turn-in response (finish braking to turning in) and steady state balance (from apex to track out), I found that lowering the front ride height by 0.5" (from stock) improves the turn-in response without altering the steady state balance significantly.
I used 245/35/18 in the front and set the coilover to 0.5" lower last weekend and was happy with the result.
Here is a short clip
      10-06-2010, 10:06 PM   #6
r4gs
Viper Driver
Singapore
36
Drives: F-16
^master apex, which track is that?
      10-06-2010, 10:24 PM   #7
O-cha
O-cha's Avatar
218
Drives: Mcoupe
WTH are you talking about? I can't believe you're calling the Mcoupe unresponsive with poor turn in.
      10-06-2010, 11:14 PM   #8
chanzs
Think the post title is wrong and misleading. Initial turn-in is fine but rather its the time it takes the car to settle that bothers me. I find that the body rolls and pitches a little too much for my liking, particularly in quick S-bends where the body weight takes a long time to roll from one side to the other, resulting in some instability and easy loss of rear traction? i apologise if I made this even more confusing... newbie.
I was thinking a thicker anti-roll bar may help but there doesnt seem to be any options out there. I'm also considering coilovers but would like to be sure that it would help cure thie 'issue' before investing big $$$ into a coilover system.
      10-07-2010, 10:58 PM   #9
Master Apex
Texas World Speedway.
Highest speed HPDE track in Texas.
Z4M red line 4th gear at 140mph on the straight.
The Viper ACR reached 165mph before braking.
      10-08-2010, 10:00 AM   #10
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
Nice video. I've only been to TWS once so far in the coupe, and I have a ways to go before I reach 140. I do enjoy that track, and the Coupe is much better there than my E39 M5 Talk about waiting for the weight to settle. Did it once, will not do it again.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      10-22-2010, 08:23 PM   #11
silversprint
Drives: Z4M
It ain't no lotus.
You have to basically drive it slower into corners.
MR-S Track -2100lbs/300hp
Miata
Z4M Coupe (Sold)
      10-27-2010, 08:49 PM   #12
blender
Custom User Title
blender's Avatar
Drives: black
Stiffer springs and matched dampers [typically lowered but not always] will reduce body roll at the cost of some ride comfort. Most of the quality coil-over setups will reduce sway and provide significantly better handling. Several vendors offer bigger anti-roll bars for reducing side-to-side sway.
Alignment and especially corner balancing will help reduce any pendular front-to-rear sway.
This car is not lotus-light but it it stiff and can be made to corner flat and fast.
      12-21-2010, 11:24 PM   #13
tarheel91
Drives: ESS Z4 3.0i
Short of increasing the roll center height (which requires reworking the suspension geometry) and thus changing the ratio of geometric to elastic weight transfer, stiffer springs and matched dampers are the way to go.
One thing this will NOT do, though, is reduce weight transfer. It just makes it transfer faster.
      03-10-2011, 04:11 AM   #14
IRunOnE
Drives: Z4
i prefer 0 toe and running higher front air pressure will lead to understeer mid corner.
zpost
