ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Suspension and Braking Chat
      01-09-2010, 05:51 PM   #1
stubble88
Drives: 2013 e92 ZCP blue
Adjusting Camber
Why cant I find a write up on how to do this?
I just got the car and want to max the neg camber front and rear.
What bolts? Where? When?....etc...
2009 M coupe
help
thanks
      01-09-2010, 06:41 PM   #2
03BeastCharmer
03BeastCharmer's Avatar
257
Drives: '13 M3
Assuming you mean a 2006 M Coupe, most pull the alignment pins, and take it to a shop to have the alignment done, and get around -1.4 (+/- 0.3) on the fronts. I pulled the pin and was only able to get -1.0 No real DIY information since most aren't going the alignments them self.
Current: '13 E92 M3 Euro Delivery
Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3
      01-09-2010, 09:32 PM   #3
stubble88
yes 2006
Im more concerned with which bolts to turn in the rear or where the pins are located?
I havnt realy looked or tried yet
thanks
      01-09-2010, 11:11 PM   #4
jragan
Imola Lover
jragan's Avatar
Drives: 2007 Imola Red M Coupe
Reposting from my reply to you on bimmerforums:
Originally Posted by jragan
There are lots around the various forums, you just didn't search well enough. First adjustment is to knock out the alignment pins and push for as much negative as you can get. If you need more than that, get the Shim kit from Turner and throw a couple of the washers on. If you need more than that, then get camber plates.
Originally Posted by stubble88 View Post
yes 2006
thanks
Sounds like you'd better let an expert at a good performance alignment shop handle this for you...
His: RIP-"Ruby" E86 ///M Coupe: Pics Track Pics Short Vids Long Vids
Hers: 997-1 C4S: Pics
      03-15-2010, 05:41 PM   #5
blender
Custom User Title
blender's Avatar
Drives: black
Alignment pin [ item 1/2] [ ignore the arrow, pic is recycled]
Attachment 359528
Camber bolt shim kit for Z4M:
http://www.turnermotorsport.com/html..._ID=TSU3690036
"you can change your camber by shimming the strut and spindle with the TMS bolt kit. " ~~$16.00
Each washer adds ~~ 0.5 degree negative camber. Locktite suggested on the bolt.
Attachment 359529
Alternatively, BMW sells a thinner bolt to replace part#5, allows you to tilt knuckle before tightening it down. That's covered in other threads.
      06-02-2010, 07:25 AM   #6
inTgr8r
inTgr8r's Avatar
Drives: M2 Comp
ttt, instead of starting a new thread.
I'm going to pull the camber pins for a track session. (no alignment)
Just wondering which way will this move the toe?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold)
'13 E92 M3 Santorini Blue (sold)
'07 Z4 M Coupe Alpine White (sold)
zpost
