09-19-2009, 04:01 PM | #1 |
Rep 519
sport vs sport+ — any worries?
Questions to those of you with some seat time in the E89:
What are your impressions of the difference between sport and sport+? Have you ever gotten loose or lost it in sport+? Any sport+ worries in the wet? |
09-19-2009, 05:59 PM | #2 |
Rep 2,602
For the most part, you are reasonably safe in Sport+. Stability Control can still save you. Although, I have noticed trailing throttle oversteer. If you punch it hard in a turn, get scared, and come off the throttle quickly, the back end likes to kick out. In Sport+, I've actually had it kick out a few feet before I (or DSC) caught it.
Personally I'd not run Sport+ in the wet. I've had the Bridgestone RFTs on a 650i and it didn't like the wet at all. The Z4 is better but I'd still leave all safety systems on. One person (discussing the E39 M5) suggested to "learn from the DSC light". If you are constantly running the car hard enough for the DSC to activate, you likely will exceed the limits in Sport+ and depend on your skills to help stay under control. If you drive hard but smooth enough to not activate DSC, Sport+ will be no issue.
2020 M2 Comp, Sunset Orange/Blk: Orange stitching, DCT, exec pkg, bicolor rims Gone '18 M550i, '16 X4 M40i, '15 M5, '13 X3 35i, '12 335is, '11 X5 50i, '09 Z4 35i, '08 550i, 06 X3, 06 650i, '02 M5, '99 540i |
09-19-2009, 07:55 PM | #3 | |
Rep 85
I've broken loose in Sport+, but did so when experimenting and under conditions where I had room to slide a bit. No way in the world I'd drive using Sport+ on wet roads - I'm not that expert a driver. If you want to do that, you should seriously consider going to a driving school first. |
09-19-2009, 08:01 PM | #4 | ||
Rep 85
If you're not activating the light in Sport mode, do you think there's a reason to turn Sport+ on? |
10-17-2009, 05:02 AM | #5 |
Rep 519
Comment and question, now that I'm finally driving my Z4...
Comment: Was surprised to find that cruise control kicks out/won't engage in Sport+. Makes sense — cruise control in the wet can be like a pig on ice (nearly bought the farm in a Mustang when right wheels hydroplaned on I-95 years ago) and DSC is a definite safety plus for cruise control. But had not seen this documented before. Question: My research tells me that DSC-on/DSC-off is the only difference between Sport and Sport+. Butt dyno agrees. Anyone have more/contrary info? |
10-17-2009, 12:15 PM | #6 |
Rep 2,087
My understanding is that there is no ride difference between Sport and Sport+, which also agrees with my "seat of pants" evaluation. However, both would tend to disagree with this diagram, which I believe originated from BMW.
10-17-2009, 12:50 PM | #7 | ||
Rep 61
From the original press release...
Mike
2007 SLK350 Auto |
10-20-2009, 11:57 AM | #10 |
Rep 546
10-20-2009, 01:15 PM | #11 |
Rep 54
I would like to know this as well. I have nav and there is no option to default to sport mode. I have to manually adjust this setting every time I start the car. Frustrating.
