      12-03-2008, 11:25 AM   #1
alpinedb
alpinedb's Avatar
Drives:
UUC Shortshifter
Has anyone put this in yet or no... my cousin has an e46 m3 with a UUC SSK and i wanna put it in here
      12-03-2008, 02:21 PM   #2
mynew135
assistant to the regional manager
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
http://www.1addicts.com/forums/showt...ight=uuc+short
      12-03-2008, 06:22 PM   #3
TT1351
TT1351's Avatar
508
Drives: 135, GTS, E30 M3+
Good work Jerm, thanks for posting the link, saved me from looking for it.
Fran
      12-03-2008, 06:34 PM   #4
mynew135
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
I'm going to be installing my UUC within the next week or two. Depending on the mood that day, I may try to take pics and/or do a diy.
      12-03-2008, 06:43 PM   #5
TT1351
TT1351's Avatar
508
From my experience the mood will darken quickly, use a flash, good luck!
Fran
      12-10-2008, 04:01 PM   #6
mynew135
mynew135's Avatar
Drives: 135i
2009 135i  [0.00]
Ok, so UUC is installed. Sorry, no pics or diy, but it's basically exactly like the diy for the 335.
The UUC instructions will tell you to disconnect your exhaust, but I could not see any reason to do this and didn't do it. Still not sure why it says to do it. I did remove the 4 bolts under the trans brace, which dropped it just a tad, providing a little extra room to work around.
Hardest part of the install was the 6 tiny screws you have to install into the carrier. I was able to do 5 of them from inside the car and the other one I did from underneath the car. Just tedious work. Take your time and it's no problem.
While I was under the car, I modified my CDV. Still not sure why people are buying a modified CDV. Just tap out the restricter with a screwdriver and it's modified. Hmmmmmmmm.
UUC is amazing. A little stiff now, but from my experience with prior UUC short shifters, it will get smoother in a few days.
Highly recommended.
1addicts
