      03-10-2025, 12:17 PM   #1
2025G0540i
Drives: 2025 X5 xDrive 40i
PPF coverage details on LCI front bumper
Those of you that got ppf done on your front bumper Msport (LCI bumper). I realize all the large areas are covered but what about all the little pieces like the air dam, those little vertical pieces in the lower opening etc. Do all those areas get covered? And did you do your headlights? I'm hearing some shops won't do headlights or will make you sign a waiver because they tend to delaminate the top layer when you remove the film years later. I think I want to do my A pillars and the top of the roof in front of the sunroof to protect everything in front. Any thoughts or comments welcome.
      03-10-2025, 01:47 PM   #2
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.70]
Originally Posted by 2025G0540i View Post
Those of you that got ppf done on your front bumper Msport (LCI bumper). I realize all the large areas are covered but what about all the little pieces like the air dam, those little vertical pieces in the lower opening etc. Do all those area get covered? And did you do your headlights? I'm hearing some shops won't do headlights or will make you sign a waiver because they tend to delaminate the top layer when you remove the film years later. I think I want to do my A pillars and the top of rhr roof in front of the sunroof to protect everything in front. Any thoughts or comments welcome.
So I have a real M bumper on my M4 and the vertical pieces around the ends of the bumper are only covered on the side and not directly in the front. The front bumper PPF was done with a plotter, and it wasn't free hand cut.
I have my entire car PPF (headlights, doors, side skirts, rear quarter) the only thing that isn't PPFed is my rear taillights (I probably should of asked them to be covered too). I did not have to sign a waiver for the headlights and it's clear so there isn't any reduced output.
I have a mix of XPEL Black and Llumar Platinum on my car. XPELblack on the roof (black PPF instead of vinyl) and the rest of the car is Llumar Platinum. I used to have Llumar PPF on my roof and then had 3M 1080 vinyl sitting on top but once the 3m 1080 reached 4 years old I replaced it with XPEL black. After 4 years the Llumar Platinum came off fine with no damage to the roof.
I'm disappointed at the chemical resistance on the XPEL film because recently a bird took a dump on my car while I was driving and hit my roof and trunk, the XPEL on my roof etched only after sitting less than an hour and the LLumar on my trunk was fine. The XPEL is only like a year old and my LLumar is 6 years old. The XPEL did not heal from the heat.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension
      03-11-2025, 09:30 AM   #3
heroman
Germany
Drives: BMW X1 E84 2013
What is the cheapest way to clean the particulate filter?
      03-11-2025, 01:23 PM   #4
2025G0540i
You have a ceramic coating over the ppf? What Xpel model of film you have? I believe there's a couple price points. Surprised the Xpel performed like that. I heard bird crap can cause etching pretty quick. My installer is using Suntek film. I'd like to ppf the entire thing but I think I'll just do the complete front end, mirrors, rockers and B/C pillars for now.
      03-11-2025, 01:56 PM   #5
N1rve
Racecar Driver
N1rve's Avatar
Drives: BMW M4
2019 BMW M4  [9.70]
The only coating I have on the film is TurtleWax Hybrid Solutions Ceramic Wax Spray Coating. This is on both the Llumar and XPEL on my car.
The XPEL film I have is the Ultimate Plus Black which is essentially Ultimate Plus but just black. I've had bird crap hit my Llumar film plenty of times and it never left a mark so I think it's just an XPEL thing.
Suntek and Llumar are basically the same. They are both owned by Eastman. The one I have, Llumar Platinum is basically the same as Suntek Ultra.
Cover as much as you can afford lol. Doing my entire car wasn't cheap lol.
N1rve
      03-11-2025, 04:02 PM   #6
Arcades
In The Rain
Arcades's Avatar
8744
Drives: '24 GT4RS, '24 Macan GTS
You have to remember, PPF is porous surface. Things do etch into the PPF but most of the time, these etchings go away on their own. I have had this experience multiple times now on multiple cars. Coating on top of PPF helps but it will etch a bit, then after a few days of sunlight and what not, it just mysteriously disappears.
And if it is TRUE bird droppings and not tree saps, bird droppings will etch even on coatings (if you don't remove it quick enough).
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina"
'24 Mazda Miata RF Aero Gray "Mia"
