      01-11-2025, 06:39 PM   #1
amd413
Drives: Mazda CX5 Turbo
Swirl Marks Acceptable Right After Ceramic Coating?
I have a brand new X1 with less than a 1,000 miles on it. It’s been washed one time prior to the ceramic coating—at the same place that later did the coating. It was a hand wash place in NJ.
I paid 1200 and the car looks good, but I am seeing a ton of swirls in the right light on the hood and rest of the car. Is this something that I should raise with the detailer? I am not sure what the expectations should be, I did anticipate that if paint correction was done right, which I assume is the majority of what I’m paying for, I shouldn't have swirls at all.
      01-11-2025, 07:42 PM   #2
Jambo1
Drives: 2022 M5C /// 2025 iX xDrive50
  [10.00]
Oh man, yeah that's not good. A good ceramic coat guy would do a stage 1 cut - which is the whole point of correcting first before doing a coat. Not knowing the history of the car, even though it has such low miles, the swirls could be dealer installed during PDI, or that hand wash you referenced, or even the ceramic coat place that did a lousy job in prepping.
I would definitely bring it up with them.
Reventon Splitter /// Reventon Diffuser /// Addlights M Door LEDs /// Dinan Inlets /// Gentleman's Switch /// Paddleshifterz With Piano Black Steering Wheel Trim /// Charcoal Filter Delete /// Piano Black Side Skirts /// Funk Motorsports Turbo Blankets /// Valvetronic Exhaust /// 21" BBS F-IR /// Dinan Monoballs /// Dinan Rear Links /// Racechip GTS /// Catless Secondaries ///
Llarry26804.50
      01-11-2025, 09:08 PM   #3
stbm5
Drives: 2018 M5 DG
you shouldn't have swirls. i bet they assumed that since it was basically new they could throw a coating on without paint correction. you should take it back and ask for it to be fixed.
TboneS541354.00
FSHNGRY3112.00
      01-11-2025, 09:41 PM   #4
rmedina
Drives: 2023 M340i
All cars need paint correction. Doesn't matter if they are new or not. Swirls, marks, etc. are put on at the processing centers or the dealerships during prep. BMW still uses the old fashion car washing systems.
      01-11-2025, 09:44 PM   #5
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
Swirl marks on a newly ceramic coated car is unacceptable. I had the beginning of clear coat failure on my ‘09 E92 so I had the hood, roof and trunk lid repainted. After three or four months, I compounded the old paint, polished everything and then ceramic coat. It’s been eight months since applying the coating and it still looks great. I would have the shop look at it and give them a chance to make it right.
      01-12-2025, 12:55 PM   #6
Nettles
Nettles's Avatar
847
Drives: M340i
Post pics because everyone’s definition of “a ton of swirls” will vary. $1200 is not a 100% paint correction process. You will have 20%-30% swirls after a one step depending on prior condition. Part of this story will definitely be your expectations are high. Having said that no harm in having an open conversation with your detailer. “Hey I still see swirls did you do a full paint correction or more of a one step to get the paint ready for ceramic”. Pay attention because I’ll also take a guess that his services were listed out in some shape or form on what the $1200 included.
co_440i284.00
      01-14-2025, 10:37 AM   #7
cooolone2
cooolone2's Avatar
723
Drives: 20' M240iX B58, 01' 330XI E46
Yeah, when I picked up my brand new 15 mile car, it had swirls from the prep... Dealers don't do correction, they just take out the obvious mistakes!
Prior to ANY paint protection, even sealing and polishing, some correction would be expected.
Agree with above, they just took a look and slapped the ceramics onto the paint absent any paint correction! Crazy!
But they now own it, and need to fix it! If they refuse, let them know you'll take it to someone else, record details including pictures or videos showing problem and then take them to court to recover the cost! Don't play, it doesn't pay!
      01-14-2025, 10:43 AM   #8
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
Yep unacceptable, at that price I'd consider myself scammed. Plenty of business do sahdy shit like this thinking no one will bat an eye. And then when you complain against them they will make you run in circles and claim you're the problem.
      01-15-2025, 08:46 AM   #9
tdott
S.FL S65 Specialist
4325
Drives: M3
You really should be asking if they do paint correction before you get work done, not after.
There are some not so great detailers out there that just slap ceramic coating on top of paint defects without fixing it. (also without telling the customer they need to pay more to fix defects)
and that's where you need to make sure you are getting value for what you are paying, cheap prices usually mean cheap work. But also paying $1200 doesn't guarantee good work.
Always gotta do your research before hand.
A proper detailer will not quote you a price without seeing the car, and some will even do a test spot to confirm if a 1 stage paint correction will remove defects or if you need to pay extra for a 2 stage.
      01-15-2025, 03:00 PM   #10
1Mors
1Mors's Avatar
Drives: 2022 X5 xdrive40i msport
This should of been polished out before the ceramic coating goes on. it will eventually need to be redone to get rid of the swirls and other blemishes.
      01-15-2025, 08:33 PM   #11
KevinC
your average JAMF
KevinC's Avatar
Drives: '21 M2 Comp, '19 Golf R
Sounds like the work of a flat brim vape bro at a combination tint/ceramic/car stereo/vape shop. Get a full refund via your cc and find a professional.
      01-30-2025, 11:07 PM   #12
BruinMan
BruinMan's Avatar
173
Drives: BMW X5 M50i Unicorn
$1200 is top dollar for a ceramic coating on a new car.
Should include wash, iron removal, decontamination and a finishing polish all done indoors. All this needed to be done before a ceramic coating.
Go back with a swirl detection light and show them all the swirls.
Like this: Adam's Polishes Swirl Finder Flashlight - Ultra Bright 170 Lumen Mini Light - Easily Spot Imperfections and Swirls in Your Paint When Polishing and Correcting Your Vehicles Finish.
Prove to them it wasn’t done correctly with your swirl finder light.
2021 BMW X5 M50i Tanzanite Blue II Metallic
      02-02-2025, 11:05 PM   #13
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
I would start by not going to a car wash for ceramic coating.
Have a shop that specializes in this do a proper decontamination wash, paint correction, PPF (if you wanted on certain panels) and then do the ceramic coating.
Should be damn near swirl free once this process is done... which would probably take about 3-5 days depending on the paint and extent of work
NOW: '21 M5|FSHNGRY|TARTUFO|CCB| MPE|KW|IND|EVENTURI|EISENMANN|DINAN|BBS|
GONE: '15 F82 M4|YMB| IND|MPE|KW|BM3|
GONE: '11 E92 335iS|BLKSPHR|OYSTER|
GONE: '05 E46 ZHP|DINAN STG3 PKG| https://www.youtube.com/channel/UCva...WCpLE9CH6t9Jeg
      02-03-2025, 12:49 PM   #14
tcphoto
tcphoto's Avatar
I think that it took me six to seven hours to do my car over the summer. After washing, I compounded the old painted panels, polished everything including the months old panels (bumpers, hood, roof and trunk lid) and then ceramic coated all the painted surface plus the new wheels. There should be no swirl marks including the original paint and avoid automatic car washes, they will cause swirl marks no matter what they say.
MaxVO2443.00
      02-03-2025, 06:10 PM   #15
MaxVO2
MaxVO2's Avatar
443
Drives: BMW M8 Coupe
***Wow. That's a lot of work to do. I've had cars ceramic coated before and communication is SUPER important to know exactly what you are getting for your $$$. Plenty of guys are enamored with a lower cost up front from someone that absolutely will NOT take the time to do a proper paint correction if needed before coating. They get the car back with swirl marks, and the car just doesn't look good.
Sometimes, people end up paying double due to having to have the original bad job re-done.
Going to a reputable place with lots of good references helps a lot and makes it less likely you get a bad job done. It does cost more as a general rule up front to do so but you get your moneys worth.
      03-31-2025, 12:30 PM   #16
Breakthecycle2
Drives: M3
Im running into the same issue with a hand wash place in NJ, near NYC. I got them to redo the whole car but i was wondering if you might share the name of the place?
      04-07-2025, 11:46 PM   #17
Junkman2008
"Detailing Devil Dog"
Junkman2008's Avatar
Drives: 2001 Corvette Coupe
I feel for you guys who are trying to do what is best for the finish on your cars, but are still experiencing unacceptable results. I know exactly what is causing the issues that you are having and it is completely due to the hacks who are touching your paint. I have some threads on this forum that you should look at because they will help you identify where the problems exist.
As for the OP, when a car rolls off the factory assembly line, that is the ONLY point in a car's life when you can pick it up and take it home without any kind of detailing being necessary. If you knew what your brand new car goes through from the moment it leaves the assembly line until it arrives at the dealership, you would understand why your BRAND NEW CAR needs to be CLAYED and paint corrected, even though it has less than 10-miles on it. The transportation process is brutal on a new car's paint.
      04-11-2025, 03:08 PM   #18
L337TurboZ
Drives: 2014 BMW M6 Gran Coupe
Is that including touchless car washes?
