      12-27-2024, 12:26 PM   #1
mike_va
Drives: 2025 X5, 2005 330cic orig own
C3Z tanzanite vs C3ZM vs garage door
We had a contest between the garage door and the trunk. As a result I'd like to find some touch up paint. It says c3zm on the door, which google says is modified. Is that something I can buy from BMW?
      12-27-2024, 12:29 PM   #2
mike_va
pic of the scratch
      12-27-2024, 12:31 PM   #3
mike_va
paint code
      12-27-2024, 03:41 PM   #4
Dad of Two
Drives: 2025 X5 40i
Not sure what you can get from BMW but Dr Colorchip probably has what you need.
I recently had a garage door vs open hatch on my 2025 x5 and I plan to fix it using Dr Colorchip.
      12-27-2024, 06:25 PM   #5
John in VA
Drives: 2015 228i M Sport
C3Z is Tanzanite Blue - perhaps the M = metallic. BMW touch-up is here:
https://www.bmwpartsdeal.com/parts/b...912465727.html
You should be able to get/order it from BMW of Fairfax ($38 online price) or Sterling ($46 online) if you're in NoVA. They say can't ship it (contains hazardous materials), but BMWPartsDeal.com doesn't seem to have an issue shipping it.
      12-28-2024, 11:51 AM   #6
mike_va
Thank you. I also requested a quote out of curiosity from a local place to see what they wanted to fix it, I'll add that once received to this thread.
      12-28-2024, 12:09 PM   #7
MaxVO2
MaxVO2's Avatar
443
Drives: BMW M8 Coupe
****Wow. That could have been much much worse!. My gal pal did this to her Mercedes SUV and it not only scratched it but put a nice gouge and dent in the lid!
I will show her your video and tell her BMW's are just built better and tougher which is why yours was only a small scratch!
Yes yes, I DO love living dangerously....
      12-28-2024, 12:47 PM   #8
mike_va
I think it was helped by this piece of foam (over the garage door 'handle') I put on before I trusted the height adjustment on the door!
Eyeballing it I think the foam pushed on the license plate maybe and then the screw got it. Still not totally sure.
Trust issues aside, I feel better with the foam there - a concern is that an idrive software update might clear out that door setting.
I'm thinking of changing to a larger piece of foam now to also cover the screw just below the foam.
      12-29-2024, 05:57 AM   #9
ChzBurger
Drives: X5 40i
One of these curtain obstruction sensors might be of use:
https://infinity-shield.com/products...ield-pre-order
Also, I like this double line laser better than a tennis ball:
https://goodchief.com/home/
      01-18-2025, 08:20 AM   #10
mike_va
Summary of the quote attached ~$2700. He mentioned that personally he would use the touch up paint, that I can get from the local BMW place.
