12-03-2024, 03:31 PM | #3 |
![]() ![]() 513
Rep 1,438
Drives: 2018 F48 X1 xDrive 18D
Almost looks like an aggressive cleaner was used and has dissolved the outer layer.
Retrofits done: 2TB, 235, 313, 430, 456, 508, 5DP, 322, 674 , 6CP, 323,
552 Other mods: Central Locking button on both sides, Add extra trunk lights Other info: F48 Fuseguide, CarPlay 6CP - OEM way |
Westside Guy8666.00 m3628.50 |
12-03-2024, 03:33 PM | #4 |
![]() ![]() ![]() ![]() 680
Rep 962
my thought too. looks bad. can't imagine trying to polish that either.
Westside Guy8666.00 |
12-03-2024, 04:24 PM | #5 |
![]() 143
Rep 226
Someone sprayed a cleaner or chemical on it and damaged the plastic. I really don't think you can clean that off. Since there isn't much hope, you can try to polish it with a multi-step process. Is it touch screen? That may lead to bigger issues if you polish?
12-03-2024, 07:42 PM | #7 |
Rep 962
it looks to me that previous owner really screwed it up. i have no experience with this particular scenario but you could try a very fine polish on a small area and see if you can make any progress, if you do then polish the whole thing. what year is the vehicle? i wonder if that part is replaceable???
12-03-2024, 09:47 PM | #8 |
![]() ![]() 4672
Rep 2,076
Drives: 2023 G81 M3 Touring
Garage List 2025 Volkswagen Tou ... [0.00]
23 BMW M3 Touring [10.00] 08 AM V8 Vantage Ro ... [10.00] 22 Toyota LC 300 [10.00] |
Looks toast, those screens have coatings on them to reduce reflections and it looks like whatever chemical has been used on it has damaged that coated.
Every chance you'll have to replace the unit. |
12-04-2024, 09:35 AM | #10 |
![]() 5880
Rep 3,440
Reminds me of the damage caused on plasma TVs would get when people use any chemicals on the the screen. Plasmas have an anti-reflective coating on them and are only cleaned with distilled water and a microfiber towel.
12-05-2024, 01:43 PM | #11 |
YNWA
![]() 1354
Rep 1,065
I would would try to polish a small area (maybe top corner) by hand (mf towel) using a weak liquid polish like a plastic polish (mothers/meguiar's) or final polish type product. If no improvement at all, I wouldn't go further. Leave it as-is or replace.
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
12-06-2024, 03:33 AM | #13 |
![]() ![]() ![]() ![]() ![]() 791
Rep 1,042
Drives: E92M3, F10535i, 15 M5,340i,X5M
Alchol will make it worse, that screen is already damaged, you need to replace it.
12-30-2024, 07:46 AM | #14 |
![]() 201
Rep 118
Drives: 2025 BMW Z4 30i & 2018 MX5 RF
If you are going to try polishing the screen I would look at NOVUS Plastic Polish. https://novuspolish.com/
