11-30-2024, 06:00 PM | #1 |
Rep 3
DIY Wash + Detailing Starter Kit Advice
Hi,
I'd like to start washing and detailing my G83 M4 Convertible myself and was hoping to get recommendations for a list of shampoos, detailers, brushes, etc that I can pick up (hopefully taking advantage of Black Friday/Cyber Monday deals) and put together a starter kit for myself. I've been watching the Esoteric videos so I'll be opting for 2 bucket wash but would like a recommendation for a foam cannon as well. I'm also not sure what products to use on the softop for cleaning so would like advice there as well. The car also has full PPF and ceramic coating on the exterior, wheels, and interior. Thanks so much in advance! Last edited by avislash; 11-30-2024 at 06:01 PM.. |
12-01-2024, 09:15 AM | #2 |
![]() 1502
Rep 1,685
There are a few recent threads on this (excluding soft top care). Those might be a good place to start.
https://www.bimmerpost.com/forums/sh....php?t=2037825 https://www.bimmerpost.com/forums/sh....php?t=2137155 https://www.bimmerpost.com/forums/sh....php?t=1590418 https://www.bimmerpost.com/forums/sh....php?t=2139011 WRT foam cannon, are you looking for one to attach to a garden hose or pressure washer? I use Griot's Brilliant Finish foam cannon. I was too cheap for a Mosmatic and think any reputable brand will work fine. I also have Griot's hose end foam cannon but haven't used it in forever as I've been experimenting with foam sprayers to use during the winter when I won't have access to a water spigot. https://www.amazon.com/dp/B095KVWMZ4...p_mob_ap_share For MF towels and wash mitts, I go with The Rag Company. I like their Gauntlet towel for drying. It would also help to know how far down the rabbit hole you want your 'starter kit' to go. I take that to mean a simple/basic set of tool/, products. If correct, for exterior, just focus on:
The list can go much longer but it depends how deep you want to go. I didn't touch upon orbitals (DA ir otherwise), polishes, pads, etc... as it sounds like your car is pretty new. So, you shouldn't need to worry about those just yet (plus you car is coated). Focus instead on proper washing and drying techniques as well as getting your own process down.
- Jeff
bosstones' flickr Last edited by bosstones; 12-01-2024 at 09:19 AM.. |
12-01-2024, 03:39 PM | #3 | ||||
Rep 3
Hey thanks for the detailed response!
Also, any recommendations for a soft top cover brush and cleaner? Thanks! |
12-01-2024, 07:18 PM | #4 | |||||
![]() 1737
Rep 2,840
In my experience (maintaining 4+ cars for decades), most of the following product lines are excellent (in no particular order): There are about 10^x more product lines out there, some better (and more expensive), most worse (and more expensive) than the above. Start with whichever one is running best sales right now, and build from there! Quote:
Eventually, you might want something with 2+ gallons per minute (GPM) flow to speed up the process. PSI do not matter for automotive application. Griot's foam cannon (there are others) is pretty good. Foam cannons GREATLY simplify and speed up car washing! Leaf blowers GREATLY simplify drying, especially after wax/ceramic/graphene coating have been applied! Quote:
Don't forget an ample supply of microfiber towels as well! And an orbital polisher (or two), when ready! Go to the above vendor's web sites, and search for "starter kits". Quote:
With quality degreaser and iron remover + regular maintenance, a dedicated wash glove is all you need. Something like this will work. If you are looking to clean-up wheels with 5+ years of track pad dust baked into them, THEN you need custom brushes and acidic chemicals. Quote:
Using one regularly is more important than the difference between brands! HTH, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 12-01-2024 at 07:35 PM.. |
avislash4.00 |
12-02-2024, 11:28 AM | #5 |
![]() ![]() 1575
Rep 1,292
I add ONR at 64:1 to the foam cannon. I also use it for just about all the uses on the label. clean, clay, etc. Also use at 64:1 in the windshield washer fluid.
2015 Sakhir/Sonoma (first one totalled) 2nd one MHD and BM3, Eventuri, Mosselman, NICECNC, MAD FAT BOY DP, "Valvetronic Designs" single mid, PAGID RSC1, Hotchkis/GTMore, Vorschlag, Bilstein B16/10.
Soon Powerflex diff brace. |
starlights473.00 |
12-08-2024, 11:18 AM | #6 |
Rep 9
starlights473.00 |
12-08-2024, 04:12 PM | #7 |
Rep 12
12-10-2024, 11:14 AM | #8 |
![]() ![]() 1575
Rep 1,292
Not as much as using Adams/Maguire's Gold 30/70. Independently neither as good independently.
bac09.00 |
12-22-2024, 03:35 PM | #9 |
![]() ![]() ![]() ![]() 473
Rep 897
This is probably not the response you are seeking however, I use one to two gallons of Distilled water with ONR for waterless wash (less water wash?
avislash4.00 |
