10-01-2024, 07:11 PM | #1 |
Rep 4
Fixing Rock Chip under Ceramic Coat
Hello Everyone!
I purchased a new M340xi last month and I am blown away with the car. It is painted Skyscraper Grey Metallic. To protect it, I scheduled a full ceramic coat on the car. Before I could bring it in, the passenger door was dented or hit. (Not sure). I provided Dr. Color chip to the shop to fill in the chip before ceramic coat but they did not fill it in all the way and then coated on top. I am looking at how to fix it myself as most shops want to respray the entire door which is out of the question. I am not so much worried about the match of the color than I am the depth. I was thinking to either polish the ceramic off, fill in the rock chip, wet-sand with 1500 grit to level then polish. Or I could take a piece of 1500 grit sandpaper on the eraser of a pencil and work my way down that continue with fill and re-polish. (Close to what Ammo NYC teaches) Any advice would be greatly appreciated to fixing my car. Thanks! |
10-01-2024, 07:20 PM | #2 | |
![]() ![]() ![]() 4979
Rep 5,059
My one add-on is to get something like a magnifying glass and have good light so you can see exactly what you're doing and not over-do it. And go as light as you possibly can with each step (only as much pressure and as much time as needed), because if you get down to the primer layer... well, you know. |
10-02-2024, 10:41 AM | #3 |
YNWA
![]() 1354
Rep 1,065
Honestly, it looks fine, forget about it.
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
