      05-03-2024, 06:29 AM   #1
capsE39540i
capsE39540i's Avatar
Drives: e39 540i
Car info:
1998 e39 540i
MID unit + DSP button (no DSP screen)
Hi -
I recently replaced my ignition cylinder housing. And since I reinstalled the steering wheel, the stereo controls IE. Volume up volume down next song last song, etc., is not working. However, my cruise control and auto for climate control is working on the steering wheel. I think it could be the clock spring, however I am curious if anyone else recognizes this issue.
One additional thing I wanted to mention is that I recently sent out my Radio MID + DSP for a new LED ribbon to be installed and when I plugged the radio back in, I was able to set the date and time and a few other things, but then the radio completely froze and is stuck on the same radio FM station unless I put a tape in but once I remove the tape, it still stuck back on that same radio station. Does anybody have any ideas as to what the issues I am dealing with are?
      05-03-2024, 06:53 AM   #2
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
No clue, but welcome to the forums, hopefully someone will chime in.
      05-03-2024, 06:57 AM   #3
capsE39540i
Drives: e39 540i
Thanks MADBMW first time posting - excited to hopefully, figure out some lingering issues.
      05-03-2024, 07:07 AM   #4
MADBMWX5MC
MADBMWX5MC's Avatar
I wonder if you would have better luck with an answer if you posted your question here: https://e39.5post.com/forums/index.php
Assuming that your E39 is between 2004-09?
      05-03-2024, 09:15 AM   #5
Jeff S
Jeff S's Avatar
Drives: 2008 E92 335i, 2011 E90 328i
you might try here:
https://www.bimmerforums.com/forum/f...1996-2003-(E39)
A lot of good E39 peeps in there
