      02-26-2024, 01:52 PM   #1
mimeport
Drives: BMW X7
xpel ceramic coated - car wash soap recommendation
I have front of '24 X7 PPF'd (xpel) (hood, a-pillars etc.,) and ceramic coated the car (xpel fusion plus). Was thinking of buying foaming ph-neutral soap/shampoo and came across Adams Graphene Shampoo which seems to indicate it's 'ceramic friendly'. Any suggestions if this or what is best to use?
      02-26-2024, 02:03 PM   #2
SwissMTNAlien
Drives: 2024 M3 Competition XDrive
I just had my M3 ceramic coated using CQuartz Professional by a reputable shop with a lot of experience. He told me that Meguiar's Gold Class soap will work just fine so that's what I bought.
      02-26-2024, 02:15 PM   #3
tracer bullet
tracer bullet's Avatar
Interesting. I'd think they'd know and probably go with it...
I'd read however, and it says on their page, this particular soap will "condition paint" and so I was always unsure if it left something behind. The label on it also says it's "shampoo and conditioner".
I don't know what's in it, or if it's bad at all, but many soaps do include waxes and such, and the Meguiars terminology makes me second guess it. I know you can't hurt a ceramic coating at all but my gut feeling is to not mix and match protection types. Not that much will stick to a clean ceramic coating anyhow... But if you do as a next step spray on any sort of supposed ceramic booster, Again I'd reconsider having any sort of other waxes or polymers under it.
Just something to think about.
      02-26-2024, 02:16 PM   #4
ppointer
Drives: '01 Z3M, '12 335is, '22 540i
2009 528i  [8.60]
2022 BMW 540i  [0.75]
2008 Infiniti QX56  [5.00]
1967 Chevrolet Corv ...  [10.00]
2012 BMW 335i  [8.29]
2001 M Roadster  [10.00]
2012 BMW 335is  [7.93]
2013 BMW M3 Vert  [9.67]
+1 on the Meguiars. Seems to have preserved the ceramic on three cars I have where it has been applied.
      02-26-2024, 09:57 PM   #5
cozye
cozye's Avatar
717
Drives: 2024 M3 Comp - 328ix (hers)
any ph neutral soap is fine. i’m using adams mega foam
Nettles846.50
      02-27-2024, 08:13 AM   #6
mimeport
Drives: BMW X7
Yea leaning towards Adam’s mega shampoo as well!
      02-27-2024, 09:45 AM   #7
icj_45e
Drives: 23 X5 45e
Carpro Reset is a great shampoo for ceramic coated cars too
Nettles846.50
spazzz192.50
USMC_Sam205.50
      02-27-2024, 10:45 AM   #8
pikkagtr
Go Spurs Go
pikkagtr's Avatar
4061
Drives: '22 GR Z4 Coup '06 Z4M Rdster
Chemical Guys Hydrosuds in foam cannon
Adams Ceramic boost detailer for spots
      02-27-2024, 01:45 PM   #9
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
I have full PPF on my 23’ I7 and I use Adam’s shampoo PH and it works perfect
      02-27-2024, 01:59 PM   #10
DocL
DocL's Avatar
Drives: 2018 M3 Comp 6spd
I have front end PPF and entire car ceramic coated. I use Meguiars and don't have any issues. I only was my car once a month so that probably helps too.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance."
      02-27-2024, 02:15 PM   #11
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
Which meguiars do you use
      02-28-2024, 08:18 AM   #12
DocL
DocL's Avatar
I don't recall. But I get it at walmart lol.
      02-28-2024, 08:50 AM   #13
Gemini7866
Gemini7866's Avatar
Drives: 2023 i7
2023 BMW I7  [10.00]
Thanks I’ll look for it
      02-28-2024, 09:06 AM   #14
DocL
DocL's Avatar
I think it's the Ultimate Car Wash. It was recommended by the place that applied the ceramic. I also do a touch up with the ceramic spray twice a year.
Hope this helps.
-Doc
      02-28-2024, 11:39 AM   #15
Scrapula
Scrapula's Avatar
5361
Drives: BMW i5 M60
I use Chemical Guys Hydrosuds Ceramic Car Wash Soap. I also have XPel Fusion Plus on my car. It has silicone oxide, which supposedly protects the ceramic finish.
      02-28-2024, 10:18 PM   #16
xxpanipuri
Drives: 550i
I use the following for my coated car, a good pre wash (carpro lift) when its really dirty and then wash with car pro reset (or use only reset when car isn't too dirty).
      02-29-2024, 05:59 PM   #17
mimeport
Drives: BMW X7
Do you use pressure washer to foam the car or just regular garden hose?
      02-29-2024, 10:01 PM   #18
cozye
cozye's Avatar
717
Active 2.0 pressure washer and foam cannon. It’s a must.
USMC_Sam205.50
      02-29-2024, 11:19 PM   #19
P1
P1's Avatar
11742
Drives: 2004 3/4 ton Duramax
So let me get this straight. You pay a large sum of money for a ceramic coating, a supposed level of protection higher than whatever is on the market. Yet you are worried about using a "ph balanced" soap? If it can't even stand up against a car wash soap, it won't stand up to much else either.
      03-01-2024, 08:39 PM   #20
mimeport
Drives: BMW X7
Well I was told by the ppf shop to use ph-neutral wash! Hence my ask!
      03-01-2024, 08:52 PM   #21
P1
P1's Avatar
11742
You can use whatever you want, it doesn't matter.
      03-01-2024, 09:01 PM   #22
chris719
Drives: '08 M Roadster
Meguiar's Gold Class leaves surfactant film and some polymers behind. It will affect the repellency of the coating a bit. I would use Turtle Wax Hybrid Solutions PRO Pure Wash or CarPro Reset. Neither leave anything behind, the TW has polymers for slickness only. Use this as your normal wash. When it gets clogged and stops beading, use an acidic soap like Labocosmetica Purifica, CarPro Descale, or Adam's Strip Wash (yellow).
