      01-19-2024, 05:28 PM   #1
elenaceambur
elenaceambur's Avatar
Romania
Drives: BMW F30
Hi guys, I'm getting these errors on a BMW f30 2.0 n47. The problem is, in the morning when I first start it after I leave the car stationary for 10-12 hours, it starts normally, the engine sounds normal but it doesn't allow me to accelerate it over 2000 revs, and I get these errors, I leave it on for about 5-10 min , I turn it off and after 15 minutes after I turn it on it recovers as if nothing had happened, and it works normally, shoots normally, runs normally (PS if I turn it on then momentarily and don't leave it for a few minutes it doesn't recover) I cleaned the turbo actuator, you can see how the valve works when you accelerate, the turbine geometry is checked and it's ok, what could it be? Has anyone else encountered this problem? Thank you for help !
