      01-15-2024, 03:25 PM   #1
Jeff J
Drives: '24 X5M, '18 M2, '09 135i
Cleaning your car in the winter
For those of you who live in places with snow, salt, and lengthy periods below freezing, how do you keep your car clean?
In my area the automatic touchless car washes are closed below freezing. My garage doesn't have a floor drain for attempting any kind of bucket/hose wash/rinse, and it's way too cold to use the outside hose reel or leave the garage door open.
At this point I'm not looking for show-car clean. I just want to remove some of the road salt and other chemicals. The forecast shows high temperatures below freezing for the foreseeable future, so I'm not sure what approach to take.
      01-15-2024, 04:15 PM   #2
T-Dubbs
Coal Troll
208
Drives: '14 F10 535d
My car normally stays dirty untill the weather allows me to rinse it off.
My hybrid burns Diesel & Oil
deleted F10 535d
      01-15-2024, 04:21 PM   #3
John in VA
Drives: 2015 228i M Sport
Rinseless wash with tons of microfiber towels seems to be the solution!
https://www.youtube.com/watch?v=BJRJ...el=McKee%27s37
https://www.youtube.com/watch?v=hzZQ...riot%27sGarage
https://www.autogeek.net/keeping-you...n-winter.html/
https://www.youtube.com/watch?v=kXQt...el=McKee%27s37
https://www.detailedimage.com/Ask-a-...-washing-tips/
      01-15-2024, 05:16 PM   #4
TheMidnightNarwhal
TheMidnightNarwhal's Avatar
Drives: 11' 335is DCT
I rinse it every week at coin wash and when the the weather in my unheated garage permits it, I'll do a rinse less wash on it (after rinsing it at coin wash) but that's for show car clean, when I really want my car 100% clean compared to all the other cars around lol. I don't even have a ceramic coating on it yet just use a spray type product every time I wash it and it rinses nicely on the weeks I don't do rinse less. Can't wait to get CarPro CQuartz on it next year.
I'm surprised in your areas touchless car wash are closed when freezing. But yeah in your situation I'd be doing automatic touchless washes every week or so. You can probably still do a rinse less without a drain. Especially if your garage is heated must be nice!
      01-15-2024, 05:38 PM   #5
WayneM3
Drives: F90M5
I live in NYC now so my car ends up staying dirty much longer than I would like - especially with all of the salt used around here.
I grew up in NJ and decades ago I was at an NSX event with the owner of Zymol and he showed us that he ran hot water to the garage. We liked that idea so my father plumbed that in. What a difference it makes to be able to use warm (or hot) water through the hose. I used to be able to wash the car when it was very cold out and not feel like I was freezing my hands off. If that is an option, I highly recommend it.
      01-15-2024, 06:32 PM   #6
jkoral
Drives: 2017 M2 LBB 6MT
Originally Posted by WayneM3 View Post
...he ran hot water to the garage. We liked that idea so my father plumbed that in. What a difference it makes to be able to use warm (or hot) water through the hose. I used to be able to wash the car when it was very cold out and not feel like I was freezing my hands off. If that is an option, I highly recommend it.
+1. It's not super cold here in New England, so anything in the mid 20s (F), I'll wash in the driveway with warm water (bucket will be scalding hot). Driveway will be freezing under my feet, but blow dry and back into garage. Winter roads typically have so much slop, impossible to keep clean if you daily drive, but it's enough to satisfy me.
Anyone use any of the cheap pressure washer undercarriage attachments (nozzles on wheels)? I've been thinking about one to get salt off suspension and other components not covered by the underside plastic panels.
      01-15-2024, 07:11 PM   #7
spazzz
spazzz's Avatar
193
Drives: 2008 535xi MHD&XHP,2013 X1 35i
I have the Ryobi water broom. I had to grind down the stop so it would adjust to the proper 90 degree angle when using the wand under the car.
Works great for me.
When it is a bit warmer with dry roads(not packed snow covered), I will fill a gallon pump sprayer with McKees rinseless solution and pre- rinse the car.
This gets a lot of the sand and salt off. I usually have to fill the sprayer twice.
I will also hit wheels plus barrels, undercarriage and wheel wells.
Then I will use Carpro ECH2O and 8 or more TRC Eagle Edgeless 500 to do a rinseless.
If it's above freezing I will use the pressure washer for a Reset wash and squeegee the water out of the garage when done.
My garage heater helps a little with the process.
      01-15-2024, 08:45 PM   #8
Jeff J
Great comments, all! We're currently sitting at about 5F here with a -10F wind chill, so running any kind of water outside (at least here at my house) is a bad idea. The garage does stay above freezing (currently 38F), so some kind of rinseless product might be an option.
I'll have to check out the self serve manual spray car washes to see if any of those are open / operating. Maybe they've been wise enough to plumb themselves with warm water for winter use.
We climb all the way to 21F tomorrow, but the wind picks up and the wind chill plummets (school has been cancelled since it will be -20F with the wind). At ~20F I don't feel as bad about running someone else's water - at least it won't freeze to the car as fast as I can spray it!
      01-16-2024, 06:26 PM   #9
lens
lens's Avatar
2273
Drives: 2018 340i xDrive
If it's not snowing or raining, and it's dry roads out, I'll bring it to the coin car wash and spray it down with soap and water (my car is ceramic coated) and dry it with microfibers to get rid of whatever dirt is left on the paint.
Normally try once a week, if not once every 2 weeks.
If it's uber cold out, i'll try to find a warmer day to do it, my car is parked in a heated garage anyways.
If your car is ceramic coated, I would only use the cheapest wash they have available, and only use touchless when you really need to, the soap they use is normally pretty harsh.
Bootmod3, CTS Catless DP, B58TU HPFP, XHP, BM3 Flexfuel Kit
      01-16-2024, 07:54 PM   #10
LouK
LouK's Avatar
Drives: Ram TRX F90 M5
another for coin DIY washes. Made sure to use the "wax" spray as the final spray off as it seemed to not freeze up immediately and allowed me to dry the car off.
      01-20-2024, 10:11 AM   #11
co_440i
Drives: 440i
Wait for a day above 40 lol
      02-11-2024, 09:30 PM   #12
Jax327
Jax327's Avatar
885
Drives: 2024 M3 Competition Xdrive
I have a garage but use this griots timeless wash and have been very happy with results so far. I use a pump sprayer to apply it and fill up a bucket with the solution as well. Just have a lot of towels.
https://a.co/d/cun08q0
      02-12-2024, 07:50 PM   #13
nazali
nazali's Avatar
Drives: 230 2020 vert F23
There is a school of thought that this is not the greatest of ideas,
Keeping salt of the car and bodywork helps a lot
      02-12-2024, 07:52 PM   #14
Mosaud1998
Mosaud1998's Avatar
Drives: 2019 BMW 540
2019 BMW 540  [0.00]
Buy a winter beater. Problem solved
At least, that's what I did.
Current: 2019 BMW 540 (AWD) & 2006 Honda Accord EX-L V6
Sold: 2009 BMW 328 (AWD)
      02-17-2024, 05:51 AM   #15
MADBMWX5MC
MADBMWX5MC's Avatar
Drives: 2023 BMW X5MC
^Good one, I try to clean as I can.
      02-17-2024, 07:33 AM   #16
disintegrator66
disintegrator66's Avatar
Drives: '18 340i M-Sport 6MT THP MPPSK
I've been using the Erie Tools undercarriage unit for 3 years and I'm happy with it. My 340i is pickled for the winter, but I have three other cars to keep clean so I basically run my pressure washer year round. I keep it in the basement and just run the 75' hose out of the garage to the driveway...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
jkoral1266.00
      02-23-2024, 08:34 AM   #17
zero2sixtyZ
Drives: e92 + f15
If it's too cold for a full bucket wash, I head over to the coin op wash just for water. iK Foam Pro 2 foamer filled with water and Adam's Car Shampoo as a pre-soak and Sonax Wheel Cleaner for wheels, then rinse off. They have the dryer guns available at the booths here, so I use them for the seams, mirrors, wheels, etc.
It's not spotless or perfect, but easy enough to do every 7-10 days to keep salt off.
E46ZHP259.50
      02-24-2024, 10:27 PM   #18
P1
P1's Avatar
11742
Drives: 2004 3/4 ton Duramax
1) find a place where you can power wash the vehicle and get most of the heavy grime off
2) park car in garage and wash it with Optimum No Rinse
      02-26-2024, 12:13 PM   #19
alex2112
Drives: 2025 BMW M340i
Here in New England the automatic touchless wash bays never close, even when the temperatures are well below freezing so I regularly run my car through one every week or so, or a day or two after a storm where the roads were salted.
Every fall, right before temps get below freezing I do one last pre-winter detail where I seal and wax the car using Meguiars M21 topped with Collinite 845. The combo of those two lasts until well into spring even with regular touchless washes.
