      12-10-2023, 04:30 PM   #1
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
Debadging
Some stubborn adhesive residue that I need to attend to. Tried 3M adhesive remover and Goo Gone. Any other suggestions to help remove?
///Sursum Ab Ordine
      12-10-2023, 11:15 PM   #2
P1
P1's Avatar
11742
Drives: 2004 3/4 ton Duramax
I don't have a problem with 3M Adhesive Remover but Goo Gone I've had bad experiences with. Tried to get some stuff off a number plate once and the actual paint started rubbing off.
UPSROD1191.00
      12-11-2023, 02:51 AM   #3
DubaiRich
Drives: 2010 Z4; 2008 118D
2010 BMW Z4  [8.17]
I've used WD40 to remove my unwanted, adhesive-backed items.
shimmy232495.00
icj_45e156.50
Jbrown74032948.00
      12-11-2023, 08:26 AM   #4
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
another vote for wd40. i then follow up with a iso spray and wipe down, then polish.
      12-11-2023, 08:32 AM   #5
unluky
unluky's Avatar
7811
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Rubbing alcohol is my go to..........
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
      12-11-2023, 09:19 AM   #6
GOLFFRR
GOLFFRR's Avatar
11553
Drives: GOLFFRR cart
Ive also had success with WD40
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY MATT FIRST!
Matt Sales:mlui@bmwofcamarillo.com Cell:805-300-9713
vipfinance@bmwofcamarillo.com for warranties!
      12-11-2023, 10:05 AM   #7
Mike02z
Mike02z's Avatar
Drives: 2024 BMW M4 Manual
2024 BMW M4  [10.00]
This^^
90% or higher alcohol is the ticket. The non medical 66% won’t work as quickly
      12-11-2023, 10:11 AM   #8
unluky
unluky's Avatar
7811
Originally Posted by Mike02z View Post
This^^
Good catch - this for sure. On a cotton ball and dab it on an let it sit a sec and run with your finger and repeat. Even used a plastic vinyl wrap tool to scrape at it a bit till the thick shit is off. Patience is a virtue here.
      12-11-2023, 10:34 AM   #9
Mike02z
Mike02z's Avatar
2024 BMW M4  [10.00]
You can also use your thumb and roll the adhesive off I’ve given myself blisters doing that but it often works.
      12-11-2023, 09:27 PM   #10
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
WD-40 cleans it off well. Followed with detailing spray and then some wax.
      12-11-2023, 09:54 PM   #11
Prince Thundernight
Prince Thundernight's Avatar
Drives: 2023 BMW M240i XDrive G42
Lighter fluid
2023 G42 ///M 240i xDrive Thundernight Metallic
      12-12-2023, 05:24 AM   #12
tallslenderguy
tallslenderguy's Avatar
41
Drives: 2021 Z4 M40i
Originally Posted by PRINCE THUNDERNIGHT View Post
Lighter fluid
Do you light it after you apply?
      12-12-2023, 07:47 AM   #13
Prince Thundernight
Funny. Lighter fluid is actually very mild—you can use it to remove fingerprints from photographs, and is great from removing sticky residue.
      12-13-2023, 09:15 AM   #14
Schulminator
Schulminator's Avatar
961
Drives: 2023 SSG G80 Xdrive
3M eraser wheel is hands down the best and fastest way.
      12-13-2023, 07:17 PM   #15
gary_william
Drives: 2013 128i
Hand sanitizer (mostly alcohol)
      12-14-2023, 02:23 PM   #16
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
Update: first, thanks to everyone for your feedback. I did try most of them. But to no avail. Simply because the adhesive on the OE badge had dried up and in the process of removal, took off some clear coat.
I have two choices. Go back to badging or have the trunk face (badge location) resprayed professionally.
If I go back to badging. I'm thinking of going with gloss black. But it is another issue since most of my initial looks at Amazon; resulted in cheap prices and sub-par quality products.
Did anyone have luck with a good-quality badge finished in "gloss black?"
///Sursum Ab Ordine
      12-14-2023, 03:04 PM   #17
shimmy23
F15 daddymobile
shimmy23's Avatar
Drives: GS X5
IND!
      12-14-2023, 04:50 PM   #18
John in VA
Drives: 2015 228i M Sport
Originally Posted by shimmy23 View Post
IND!
https://ind-distribution.com/collections/exterior
      12-14-2023, 09:48 PM   #19
gaijin
Mess Deck Commando
gaijin's Avatar
Drives: F30
IND has limited emblems (mostly current new series/models). I'll give them a call and see if any NOS stuff (F3X, etc.) available.
///Sursum Ab Ordine
      12-22-2023, 07:10 AM   #20
NoMods
NoMods's Avatar
Drives: 2022 M5
2022 M5  [10.00]
The Eraser wheel is your friend, go slow at first.
RTPenland502.00
      12-23-2023, 06:33 PM   #21
espressoo
Drives: '18 M3 Comp|'23 X5 45e|'24 X7
To get the double sided tape off use an eraser wheel. Just hold onto your drill really well and go slow. To remove any tape residue this stuff works really well.
https://www.amazon.com/gp/aw/d/B006R...b_b_asin_title
      01-05-2024, 04:35 PM   #22
cwickberg
Drives: X1 35i MSport Ultimate,
Warm/ heat the area first... I've removed 15 year old badges with no real problems
