      08-27-2023, 05:50 PM   #1
clementine
Drives: X1 E84 35i
Reset comfort access after reconnecting door handle?
Hi there,
2013 X1 E84 MSport.
Comfort access stopped working on drivers side, but was still working fine on passengers side.
I remove the door handle on the drivers side, cleaned the contacts, and reinstalled it.
Now: Comfort access doesn't work on either side! i.e the passenger side (which I didn't touch) no longer works.
Question: Because I removed and reconnected the door handle, is there perhaps now some sort of reset procedure I need to do on the car?
I have tried:
-Holding down the volume button for 30 seconds
-Unlocking drivers door with the physical metal key, & starting the car with the fob physically inserted.
No dice :-(
      08-28-2023, 08:01 PM   #2
cwickberg
Drives: X1 35i MSport Ultimate,
Try disconnecting the battery for 30 minutes
      09-05-2023, 11:57 AM   #3
Gamb1t
Gamb1t's Avatar
When I replaced my CA driver's door handle, I made sure to disconnect the battery first. Hopefully you didn't short out the CA module.
I don't recall having to perform any reset. It was a simple affair.
