07-04-2023, 12:41 PM | #1 |
Rep 69
Hardwired dash cam
Hey all, sorry if not I’m the correct thread…
However, I am looking to hardwire my DASH cam into my new F40 2 Series GC. As then it won’t be plugged into the standard cigarette port… However, I have no idea what I’m looking at when it comes to fuses and where it needs to be plugged into. 1 wire needs to go into a ACC fuse port, and the other wire is BATT, so when the engine is off it doesn’t take power from ACC and the battery only…if that makes sense I have attached images with hope someone can help me |
07-04-2023, 01:04 PM | #2 |
Rep 6,319
You can use a test light/other suitable tool to probe your fuses and check which one are on in the state you want it. BATT is usually a fuse that always has power even with car off (for your parking mode to work) and ACC goes on a fuse that is only on when ignition or accessory is on to tell the camera when to switch from parking to normal mode and other way around.
BMWBudgie18.00 |
