06-08-2023, 06:54 PM | #1 |
Rep 2
2014 X1 chassis stabilization malfunction
Hwy guys, just changed every suspension component on my 2014 x1 28ixdrive front and back along with lowering springs. Bolted everything back up, started to take it to get aligned and the chassis malfunction code popped up so I pulled back in the driveway. I checked all the wheels speed sensors, cleaned them out put them back. Made sure both of the control arms on the ride height sensors were fastened securely and plugged in and anything else I could think of. Unplugged the battery, took it back out and it came right back on. My steering wheel is a bit out of alignment after the tie rod change, could this have anything to do with the error code? Didn’t want to keep driving it without knowing the cause. Appreciate any help, thanks!
Shane |
06-11-2023, 06:21 PM | #2 | |
Rep 289
06-17-2023, 09:00 AM | #3 | |
Rep 12
1.Turn the steering wheel to the left and hold it for two seconds. 2.Turn the steering wheel to the right and hold it for two seconds. 3.Turn the steering to the left, then to the right one more time. 4.then bring the steering wheel back to the center. You know when you lowered your car your suspension geometry changed right ? You need stiffer Shock/Strut/Bushing and Camper Kits to handle the lowered car, I just want to give you an advice, i studied suspension for years. |
