05-04-2023, 10:59 AM | #1 |
8662
Rep 10,924
What's your pressure washer setup?
Pressure washer (gas or electric)- Ryobi, Active, Sunjoe, Kranzle?
Hose - Uberflex, flexzilla? Wand - MTM? Curious to what you guys are using. I plan on upgrading my setup for maybe weekly or biweekly use so definitely don’t need a high end setup. |
05-04-2023, 11:27 AM | #2 |
![]() 430
Rep 1,034
Pressure washer- just replaced my cheapo SunJoe with Active 2.0. I could see significant difference when using it for the Foamer.
Hose - MTM Kobrajet Wand - MTM Hydro Acqualine. Last edited by Pheonix; 05-04-2023 at 12:41 PM.. |
05-04-2023, 11:52 AM | #3 |
![]() ![]() 828
Rep 345
pressure washer : kranzle 1322ts
hose - kobrajet wand - mosmatic |
luckylingy3490.50 classic_erik2875.00 |
05-04-2023, 12:21 PM | #4 |
![]() ![]() 157
Rep 154
I'm using a cheap electric one ($100 - $120 range) from amazon. Also bought a cheap nozzle from amazon to replace the long wand. No complaints, works great. Doesn't throw as much foam as the nice ones i see on youtube detailing vids, but definitely sufficient for me.
05-04-2023, 12:26 PM | #5 |
Primo Generalissimo
![]() 5358
Rep 4,397
Drives: All of them
Garage List 2025 BMW M850i [10.00]
2024 Ford Bronco Ra ... [10.00] 2018 Porsche 911 GTS [10.00] 2022 Ford F-250 Tremor [8.50] |
I have a SunJoe but my favorite is this little red Hyper Tough pressure washer I got at Walmart for $60. Not too powerful and easy to setup/put away/move around.
05-04-2023, 12:32 PM | #6 |
dances with roads
5364
Rep 4,170
AR Blue Clean. Comes with foam gun, hose is supple enough for me. I use all of the stuff that came with it. I think they may have a newer model out.
https://www.amazon.com/Blue-Clean-BC...02&sr=1-4&th=1 EDIT: to clarify -- I have model BC383HS. |
BMW AD30.00 |
05-04-2023, 02:53 PM | #7 |
![]() ![]() 309
Rep 75
Drives: 2020 BMW 230i
Pressure Washer Ryobi 1800 PSI - https://www.homedepot.com/p/RYOBI-18...1802/317623149
Hose PWACCS (50 ft) kink resistant, comes w/ (2) quick connects - https://www.amazon.com/PWACCS-Pressu...10&sr=8-3&th=1 Wand Sooprinse gun, added a quick connect - https://www.amazon.com/Sooprinse-Pre...03&sr=8-3&th=1 Foam Cannon Harbor Freight, changed orifice to 1.1mm - https://www.harborfreight.com/pressu...non-58131.html - https://www.amazon.com/Mingle-Cannon...s%2C122&sr=8-4 |
05-04-2023, 05:02 PM | #8 |
![]() ![]() ![]() 361
Rep 395
Pressure washer: Kranzle 1122tst
Sprayer: Mosmatic swivel Wand: Mosmatic Cannon: MTM PF22 Tips: Mosmatic and MTM Water Filter: CR Spotless mounted to wall Fittings: MTM SS Garden Hose: SS Jumper hose and Eley garden hose and Eley spray nozzle |
05-04-2023, 05:40 PM | #9 |
![]() ![]() ![]() ![]() 654
Rep 618
Pressure washer...BigBoi Washr Flo with the optional commercial grade hose upgrade
Stubby gun...MTM SGS28 with Carscope premium 25° and 40° nozzles Wand...Mosmatic Foam cannon...MJJC Pro V2, MTM PF22.2 and an Autobrite Direct foam cannon (probably not available outside the UK) |
05-04-2023, 06:04 PM | #10 |
![]() 5150
Rep 3,947
Ditto
Patton2502954.00 Pheonix430.00 shimmy232493.50 Charles B149.00 FZZF0.00 Clark_Kent2337.50 classic_erik2875.00 StradaRedlands8432.50 |
05-04-2023, 06:04 PM | #11 |
sportscars only
![]() 3640
Rep 3,295
I just use this all-in-one. Great for me.
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
05-04-2023, 06:23 PM | #12 | |
![]() 45
Rep 68
05-04-2023, 06:46 PM | #13 | |
![]() ![]() 309
Rep 75
I would just Google search the strengths of the various nozzle fittings before use. |
PJ196045.00 |
05-04-2023, 06:48 PM | #14 |
Not great. Not terrible
7569
Rep 2,702
One of these hand held battery operated jobs. It's perfect for my needs, takes up little room, and uses the same batteries as my tools.
![]() https://www.homedepot.com/p/RYOBI-40...052K/318615872
Current: 2024 BMW X3 M40i.
Porsche 718 GTS 4.0. |
05-04-2023, 08:59 PM | #15 |
OG M2 🖤
55
Rep 13
Pressure washer: Original Active
Hose: 50' no name kinkless from amazon w/quick connects Wand: Cheap gun w/swivel adapter + knock-off MTM extension I'm patiently waiting for some of the cheap stuff to die/leak to upgrade but they're holding strong so far |
05-05-2023, 06:16 AM | #17 |
![]() ![]() ![]() ![]() 1023
Rep 815
Honda gas powered, 2000 psi, 2.5 gal per min.
The compressor has an adjustable regulator so the pressure can be dialed back if needed. Also a Maxshine foam cannon.
05-05-2023, 08:10 AM | #19 | |
![]() ![]() 157
Rep 154
05-05-2023, 08:55 AM | #20 |
![]() ![]() 309
Rep 75
05-05-2023, 12:19 PM | #22 |
8662
Rep 10,924
I thought the Active 2.0 was just on preorder still?
