      07-10-2022, 07:03 PM   #1
TurboSid
TurboSid's Avatar
1172
Drives: 2022 M4Cx BSM/FR
2008 335i  [0.00]
Prep for car wrap
Planning to get my car wrapped pretty soon after its arrival. Any recommendations on prep work needed or best practices for brand new paint before wrapping the car?
2022 BSM/FR M4 Competition X-Drive
2017 MW/SO M4 ZCP [SOLD] • 2015 MW/SO M4 M-DCT FBO [SOLD] • 2011 AW/CR 335is DCT FBO [SOLD] • 2008 AW/CR 335i 6MT FBO [SOLD]
      07-10-2022, 09:28 PM   #2
chicagofan00
chicagofan00's Avatar
21127
Drives: 2025 i4 M50
The shop installing the wrap should be doing all the necessary paint prep work. If they aren't, I wouldn't be using them if I were you.
Current - 2025 G26 i4 M50 in Portimao Blue
Past - 2005 E53 X5 3.0i in Titanium Silver; 2008 E92 335i in Montego Blue; 2019 G01 X3 M40i in Glacier Silver; 2022 G80 M3 Competition in Twilight Purple; 2024 G05 X5 M60i in Java Green
      07-11-2022, 09:49 AM   #3
TurboSid
TurboSid's Avatar
1172
2008 335i  [0.00]
I guess my question is more on what all I should expect to be done. Just want to know what it takes so I make sure it gets done right
      07-11-2022, 10:40 PM   #4
chicagofan00
21127
Drives: 2025 i4 M50
I would expect them to wash it up, decontaminate the paint, then do a round of polishing to properly set it up for success on the wrap job.
      07-14-2022, 06:49 AM   #5
edofloat
edofloat's Avatar
471
Drives: Outback or 992
The only thing I would add is keep the miles down and don't follow gravel trucks. I drove 12 miles from the dealer to get the car wrapped and made sure I didn't follow other traffic closely. Yep rock chip right below the camera in first 12 miles. 'Cause I'm lucky like that.
      06-20-2024, 09:39 PM   #6
NickyC
NickyC's Avatar
20452
Drives: M4 CS. Former G82, x2 F82, F80
I'd prep for the wrap by being prepared to be disappointed by it and wishing I hadn't done it in the first place.
philth569.50
Nettles846.50
Kstoff125316.50
      07-03-2024, 01:37 PM   #7
pnwwagon
Drives: 2019 F31 AW MSport
What makes you say that? Durability? Cost?
I was considering it in the event that I found the right car in a less than desirable color.
      07-03-2024, 01:45 PM   #8
TurboSid
TurboSid's Avatar
1172
2008 335i  [0.00]
Been over a year and 0 regrets. Make sure you go to a reputable place and you’ll be good 👍🏽
      07-03-2024, 02:08 PM   #9
pnwwagon
That looks great!
If you don't mind me asking, what did it run you and how long do you expect it to last?
      07-03-2024, 02:15 PM   #10
TurboSid
TurboSid's Avatar
1172
2008 335i  [0.00]
That looks great!
I didn't pay retail but I was quoted around $4-5k from local reputable shops.
The film I used (KPMF) has a lifespan of 7yrs but I'm planning to change it within a year.
I purposely bought a black car because I wanted to change the color every couple of years.
      07-21-2024, 09:46 AM   #11
rmedina
Drives: 2023 M340i
I would prep it the same way I would prep for a reset. Wash, clay or clay towel using an iron remover as the lube. Strip any coating you may have. To strip it you can either polish it or do a contact wash with dawn. Not the regular dawn, but the "Power spray". The final step should be a good wipe down with some type of IPA. Good luck
      07-21-2024, 10:45 AM   #12
Soylent
Soylent's Avatar
1301
Drives: 2025 M4C
2025 M4  [10.00]
Beer?
rmedina189.00
      07-21-2024, 12:52 PM   #13
John in VA
Drives: 2015 228i M Sport
Originally Posted by Soylent View Post
Beer?
IPA = isopropyl alcohol.
      07-22-2024, 07:10 AM   #14
Westside Guy
Westside Guy's Avatar
8666
Out of curiosity, have you decided on your next color yet? Are you sticking with the KPMF brand or are you possibly considering other companies like Inozetek which has a great reputation?
https://inozetekusa.com
TurboSid1171.50
      07-22-2024, 11:59 AM   #15
TurboSid
TurboSid's Avatar
1172
2008 335i  [0.00]
Like with KPMF my priority is getting the color I want. I looked at a bunch of Yellow swatches before I picked the one i used and it was perfect. I will go with popular brands but it's secondary, could be Avery, 3M, Inoz, KPMF etc
I know Inoz mostly has glossy colors and its generally harder to buy and more expensive to the consumer than it is to authorized installers so while it's on my radar I don't know if I will go with them.
Metro Restyling has been great at looking at different colors and brands I've mostly researched on their website.
      07-22-2024, 08:49 PM   #16
Westside Guy
8666
Of the different brands you listed do you know which is the thickest?
      07-23-2024, 10:18 PM   #17
rmedina
Drives: 2023 M340i
I've used both 3m and avery. Both are pretty easy to work with. I got everything from metro if that matters.
      07-25-2024, 09:32 AM   #18
TurboSid
TurboSid's Avatar
1172
2008 335i  [0.00]
All films will have the thickness in the specs. I believe the Inoz has a release liner over the vynil also so you can apply it then remove the vynil for a clean scratch free look.
You do have to be careful the thicker the vynil the harder it will be to contour it around edges and weird angles.
      07-25-2024, 01:27 PM   #19
VR1
Drives: E92 M3 Comp
I’ve had mine on for nearly two years now, no issues at all. The benefit of not having to worry about light scratches, bird droppings, hard water spots, etc. on the paint is also a huge time saver to me imo.
TurboSid1171.50
