SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
11-22-2008, 04:22 PM | #1 |
Rep 259
Dinan Springs came in...
Well, my springs came in last night... I weighed them right away.. The front weighed 3.4 lbs. and the rears weighed 6.4. I went out and installed the rears this afternoon. It took about 20 minutes for each side. Btw the OEM rear spring weighs 6.6 lbs. I posted some pictures, before, during and after. Not a hard thing to do at all.. I will be having a shop in town put on the fronts (I think... it depends how brave I feel tomorrow!). The first thing I notice is that the car sits a little less than 1/2 inch lower BUT the springs have not settled in. I just took it around the block... so well see what the height difference is in a few days.. More to come... Chuck I
11-22-2008, 04:54 PM | #2 |
Rep 1,660
When you had the rear spring out did you do any non-scientific comparison of how stiff the Dinan springs were compared to stock?
Current: '13 E92 M3 Euro Delivery Gone: E86 M Coupe; E30 M3, E39 M5, E36 M3 |
11-22-2008, 05:00 PM | #3 |
Rep 259
well...sort of... I can tell the Dinan was stiffer, but it's also shorter... I just put my weight on it to see how far I could compress it... that wasn't very far and that wasn't much of a test.. Chuck I
11-22-2008, 06:35 PM | #6 |
Rep 150
Drives: 2004 Z4 3.0i
There is a special at Dinan going on and they are 1/2 price for the z4M, $220 for the set.
11-22-2008, 08:18 PM | #7 |
Rep 259
I just put them on this afternoon (Saturday) and just did the rears. I have to make an appointment to get the front ones done.. I'll take more pictures as it progresses. I just took it around the block so I haven't had chance to tell any difference yet.. Chuck I
11-22-2008, 09:11 PM | #8 |
Rep 962
ok thanks, i am highly considering on purchasing a set of these. when you have everyting done would it be possible to write a review and post pics? Thanks
11-23-2008, 07:14 PM | #9 |
Rep 259
Did the Front Struts today..
Well, I couldn't wait.. It was a great day today, so it was off to the garage.. The first thing I did was remove my Strong Strut and replace the original nuts. I wanted to make sure I kept the vertical alignment of the shock and the Strong Strut was blocking my view. Then I jacked the car up using the center jacking point and put jack stands under each side. Next I removed the wheels. I started on the passenger side simply because I happened to be standing on that side at the time. I followed standard process of replacing the spring. There are several DIYs over on Bimmerfest. Anyway, got it done in about 5 hours. I just took it out and so far, I like what I feel.. It's really flat and the ride is firmer than the stock springs, but not bad at all.. I'm going to drive it for about a week and then have the alignment checked. Right now it's tracking perfectly, but I know better after a few miles.. Right now it dropped a little less than 1/2 inch but I'll see how much it goes down after the springs settle in. Here's a couple pictures, more in the day light tomorrow.. Chuck I
11-24-2008, 06:35 AM | #11 |
Rep 259
11-26-2008, 09:13 AM | #12 |
Rep 1,660
Any feedback on the feel of the car now that you have had them on for a few days?
11-26-2008, 11:06 AM | #13 |
Rep 259
To be honest, it's been bad weather here over the past couple days and I haven't had the car out. I will have it out tomorrow and will take some pictures and give you an update... Chuck I
11-27-2008, 10:02 AM | #14 |
Rep 259
Well, to be honest..
I had my car out this morning. First, to be honest, if you were looking for springs that would lower your car, these probably aren't them. The car dropped a little under 1/2 inch. If I didn't take a tape them or compare them right next to my Z4, I'm not sure I'd notice the drop. BUT, that being said, the ride firmer and the handling in a tight power turn is much better. I didn't have any noticible understeer this morning and I was hitting the turns pretty hard. These are not the springs you want if you wanted a softer ride.. but their great if you like basic stuff. Nothing fancy here, like the M itself, just fun! Below are two pictures, one from the summer and one this morning. Chuck I
11-27-2008, 01:16 PM | #15 |
Rep 1,224
Chuck,
Did you notice any difference in accelleration rear squat?
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
11-27-2008, 02:26 PM | #16 |
Rep 259
These are firmer than the OEM springs and have a little less squat but with all the torque it still goes down. My thought is, for the money and the fact that I was able to install them myself, they are well worth the price. For those who want a more agressive stance, they may not fit the bill. Chuck I
11-28-2008, 02:35 PM | #17 |
Rep 689
They might settle in a bit more once you get a few hundred miles on them. Can you take another picture then and post impressions again too?
2007 M Coupe w/NAV/Premium/Extended Leather, Clearbra, DICE, 4.10 BMW Motorsport Polished LSD, Active Autowerke Gen IV Headers, Supersprint Race Exhaust and X-Pipe, ESS Tuned DME, KWV3 Coilovers, Volk RE30, OEM Strut Tower Brace, Short Antenna, JL AMP, JL 10W7, Valentine V1.
11-30-2008, 09:23 AM | #18 |
Rep 259
01-29-2009, 03:21 PM | #19 |
Rep 4,320
Drives: '07 Z4 M Coupe
Chuck, any updates on these? Have they settled in any further?
01-29-2009, 07:08 PM | #20 |
Rep 259
The front has settled in..
The front springs have settled in very nicely... see the picture.. The rears haven't gone down quite as much as I would like, but I think they will as I put more miles on.. Chuck I
02-28-2009, 10:08 AM | #22 |
Rep 259
Settled in nicely..
Well, I was finally able to get the M out today. I just got my DME back from ECC and wanted to check it out. Well I really put the car to the test today and back springs really settled in. Now the car is perfectly level all the way round. Now if only Spring would get here! Chuck I
