      09-29-2021, 04:04 PM   #1
DSCPLN
BMW 1M
DSCPLN's Avatar
Drives: McLaren 600LT
Anyone Install a BOV on their N20 X1?
Any tips for the installation?
I have the CTS N20 BOV and an Electric Wastegate Actuator on a 2015 BMW X1 sDrive28i, and was advised I’ll need to Install a Boost Tap along with it. Where does the Boost Tap connect to?
      10-05-2021, 08:51 PM   #2
DSCPLN
BMW 1M
DSCPLN's Avatar
Ended up having the N20 CTS BOV installed at a local shop here in LA (Ghost Motorsports) without having to use a boost tap.
I brought the parts along with this Metric Long Arm Ball End Hex Key Wrench Set, which the mechanic said helped to unscrew the OEM BOV:
https://www.amazon.com/dp/B06X93DJ4T/
Although the CTS website (https://www.ctsturbo.com/product/cts...off-valve-kit/) instructs:
NOTE: If your car has an electric wastegate, you must use a boost tap in order to install this BOV.
We recommend P3Cars boost tap available for purchase here: https://www.p3cars.com/bmw/p3-boost-...w-n20-n54-n55/
seems like you don’t need it.
Also confirming tip from a fellow forum member:
Originally Posted by Jbam9
Wastegate was electronic and no did not have to do any boost tap or anything custom; it was all plug n play. it was pretty tough without removing some of the coolant line and fan in the way, but if you can remove the water pump bolts you can wiggle it around enough to get the old BOV out and the new one in. just make sure you have a long 6mm ball allen and you should be able to reach all the bolts
      10-06-2021, 10:26 AM   #3
Botlfed98
Drives: X1
do you have link to the bov you purchased?
      10-07-2021, 07:52 PM   #4
DSCPLN
BMW 1M
DSCPLN's Avatar
