      05-31-2021, 03:55 PM   #1
Silverx1kev
Drives: Bmw x1
Xdrive and staggered wheels
Hi, just got a 20d xdrive and looking at wheels but been told its a bit of a nightmare as the xdrive will play up , is there a fix or work around as looking at some x5 132 style rims , cheers kev
      06-01-2021, 04:13 PM   #2
Gamb1t
Gamb1t's Avatar
IIRC the M Sport X1s have staggered set-up.
      06-02-2021, 12:00 PM   #3
chance91
Drives: 2011 Bmw 335d
Staggered doesn't matter. It's tire diameter. I have 18x9.5 with 245/45 front and 275/40 rear, almost identical rolling diameter. Bmw official says under 2% front to rear variance.
If you aren't tracking, though, 245 or 255 square is better, if you get non directional tires you can rotate properly
https://www.tacomaworld.com/tirecalc...5r18-255-40r18
      06-02-2021, 01:45 PM   #4
aloyouis
Drives: 2013 X1 x28 MSport
This is correct. I have this set up.
      06-02-2021, 01:50 PM   #5
Kriston
The Ultimate Driving Machine
Kriston's Avatar
Drives: Like Donkey Kong on Roids
Staggered here. As long as your rolling circumference is 2% or less front to back you will be fine.
I'm running 235/35/19 front and 275/30/19 rear and have zero issues as they are identical in circumference
CHUCK NORRIS ON WHEELS
