      12-15-2019, 07:49 AM   #1
Hydrogen
Drives: 2020 G20 330i M Sport
Safely cleaning OEM G20 Jet Black rims
Looking for feedback on safe products.
They are completely glossy/clearcoated(?) jet black.
I have the general purpose Mothers' wheel cleaner which states it's safe for all clearcoated and factory painted wheels. Has anyone used this product? I've used exclusively for many years on my previous BMWs, but those were not black rims.
Thanks!
      12-15-2019, 08:27 AM   #2
WXdrivefun
WXdrivefun's Avatar
Drives: G20 330Xdrive
Never use them, but reading many reviews and in my opinion especially for German Vehicles, I use Sonax wheel cleaner or the Wheel Cleaner sometimes from the BMW dealership. My rims are the 791M Bi Colour.
      12-16-2019, 05:44 PM   #3
TTG
TTG's Avatar
Drives: M340
Just use soap and water, take your time cleaning them and you will be just fine. Wheel cleaners are a little bit of a myth and they just wont do the cleaning for you.
I also recommend using soft woolie type of brushes to avoid scratching the finish.
Below is a set that I use on my cars.
https://www.amazon.com/dp/B00L3KDUD0..._kAb-DbR3FBK26
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      12-16-2019, 06:08 PM   #4
FossieBear
Drives: BMW 3 series 320d G20 xdrive
I use acid free valet pro bilberry wheel cleaner. Diluted down. Wheel woolies to clean. Good coating collonite 845 helps too in protection
      12-19-2019, 04:56 PM   #5
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
Best response right here. In theory you want to do a proper deep cleaning of your wheels once. Use something aggressive like Sonax Wheel Cleaner and maybe clay them if you can take the wheels off and depending on how many miles the wheels have seen.
Protect your wheels with a good coating and nothing more than soap and water will be needed to clean them up. Again as suggested invest in proper wheel cleaning tools and you're set.
      12-19-2019, 11:45 PM   #6
themnmd
themnmd's Avatar
Drives: 23 X5MC
I prefer CarPro iron X and then your regular car soap with a wheel brush. Oh and ceramic coating the wheels makes cleaning way easier
      05-30-2020, 05:31 PM   #7
TorontoGambler
Drives: Volvo XC90 Inscription
My normal routine is P&S Brake buster, give it a few mins, foam the wheel, rinse after a few mins, foam again then get into the wheel with my speedmaster brush, brush the tires, detail brush the lug nuts and center cap, rinse, a few sprays of Carpro Hydro2 Lite, final rinse, dry with microfiber. Finish with Chemical Guys VRP on a foam applicator to polish up the tires. Sound like a lot but it’s a 10 mins job. Wheels are dirty, don’t use any of the water, cloths, etc on any other part of the car. Every 5 washes or so I use Carpro Iron X instead of brake buster to decontaminate.
