07-05-2008, 12:06 PM | #1 |
Rep 176
Clay
Guys what is the best clay ?
I was very pleased with Zymol but as it's so expensive for a little blue tack I tried Maguires which was not nearly as good. Is there a sensibly priced alternative to Zymol ? |
07-06-2008, 07:15 AM | #2 |
Rep 532
I've used Pinnacle clay with great results. I would imagine most clay is of similar composition with the more expensive ones either charging a premium for the brand or adding things to a base formula.
07-06-2008, 01:13 PM | #3 |
Rep 176
07-07-2008, 08:44 PM | #4 | |
Rep 95
E |
07-07-2008, 09:38 PM | #5 |
Commander-In-Chief
2175
Rep 8,942
Drives: 2023 M2 Coupe, 2020 GLE 450
Clay
I've only used Griot's, but it works fine. Clay alone is $20 for 8 oz. (good for 7 jobs, they claim), but they also have this kit:
http://www.griotsgarage.com/product/...d+shine+kit.do They also have a special holder pad so you can use it in your random orbital: http://www.griotsgarage.com/product/...ng+clay+pad.do
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
07-07-2008, 10:55 PM | #6 |
Rep 1,247
Drives: E60 M5, E71 X6M, E46 M3
Garage List 2006 BMW E46 M3 'vert [0.00]
2008 BMW M5 [0.00] 2011 BMW E92 [0.00] 2012 BMW X6M [0.00] 2003 E46 M3 [0.00] |
I may be wrong on this one...but...clay is clay is clay...the rest is marketing nonsense...
Current: 2006 E46 M3 'vert 6-sp 2008 E60 M5, 2011 E92 328 6-sp, 2011 E70 N55, 2012 E71 X6M
07-07-2008, 10:55 PM | #7 |
Rep 176
It just didn't seem as effective as the Zymol. Zymol picked up 'colour' from the small oil and tar deposits much more quickly and left the paint feeling smoother. I haven't tried one after the other just bought Meguires after using Zymol and expected the same results (so I was expecting the same experience) I think I will buy some Zymol and see if I am right !
07-07-2008, 11:07 PM | #8 | |
Commander-In-Chief
2175
Rep 8,942
Clay is clay is clay?
The clay used in a clay bar isn't really clay at all, but a mixture of a soft plastic resin (polybutene) and various grades of abrasive particles. The soft plastic resin is effectively an applicator pad, which enables you to move abrasive particles over your paint using consistent force and pressure. Because bonded surface contaminants sit above the surface of the paint, they are subject to greater abrasive forces than the surrounding surfaces when a clay bar is rubbed over them. As a result, they are exfoliated and removed by the clay bar. You use a lubricant to prevent the abrasive particles from affecting the paint. The size and type of particles and the type of plastic base used in different manufacturer's products varies somewhat, enough to make a noticeable difference with use, according to those who have tried several.
07-08-2008, 09:22 AM | #9 |
Rep 242
I am a potential first time clay user. My new M3 is 2 months old, garage kept and not a scratch on it. Do you think it is necessary to use a clay bar before i give the car its first wax. I'm a little apprehensive since i have no idea what im doing and fear damage to the clear coat.
07-08-2008, 09:50 AM | #10 | |
Commander-In-Chief
2175
Rep 8,942
