      10-09-2018, 08:05 AM   #1
MNX135I
Drives: X1 35I
Any X1 35i owners with preventative maintenance advice?
I recently purchased a used 2014 X1 35i with X drive and 60k miles on it. I absolutely love it and I am looking for recommendations for preventative maintenance. I love the V6! I live in Minnesota and looking forward to driving it this winter.
I have been reading a lot of post on this site and it appears the 4 cylinder turbo engines are more common in these X1s. Most of the discussion on this board seem more focused on that engine.
That being said- are there any glaring known issues I should be aware of with my inline 6? What are some things I should do before I hit 100k? I plan on doing new plugs at 70k. Anything else?
Thanks
      10-09-2018, 02:17 PM   #2
hooligan_G01
Space Shuttle Door Gunner
hooligan_G01's Avatar
6523
Drives: 2023 Golf R
60K is about the time that many start to consider servicing the transmission and differential - even though BMW claims those are "lifetime" fluids. I don't like the idea of "lifetime" fluids, so that's around the time I plan on servicing my trans and diff.
      10-10-2018, 09:18 AM   #3
SharpAndCunning
Drives: 2014 X1 35i
You're right, there are a lot more 4 cyl's than the 6 on here, as BMW made many many more of the 4's in the X1.
Plug are a good idea, as above mentioned the fluids at 60/70k miles. If you have a stock charge pipe, I would do a inspection of it, and make sure there doesn't look to be any small cracks forming. Plenty of people blow the OEM charge pipe at the most inconvenient time. I replaced mine, because the $100 charge pipe was worth the piece of mind being stranded and calling for a tow somewhere.
      10-10-2018, 09:40 AM   #4
KWX1
KWX1's Avatar
25
Drives: X1 Xdrive35i
Also, transfer case fluid. Check oil filter housing for oil leaks, ( it's going to happen), belt and idler pulley if it shows flat spots ( from leaking oil) or wear. My understanding is a belt failure can actually be fatal on the N55 engine.
2014 X1 Xdrive35i /BMS intake/JB4/ GFB DV/CPE charge pipe/ VRSF downpipe/ Alpina TCU flash
      10-11-2018, 11:08 AM   #5
SharpAndCunning
Drives: 2014 X1 35i
Please explain. A drive belt failure is fatal to the engine?
      10-11-2018, 11:52 AM   #6
KWX1
KWX1's Avatar
25
Belt breaks, raps around between crankshaft pulley and crankshaft seal. Destroys crankshaft oil seal and bearing. Resulting in oil loss and bearing failure. I thought the same thing, but there ya go.
See: ttps://autoscope.co/car-repair/bmw-serpentine-belt-sucked-inside-engine/
      10-12-2018, 12:31 PM   #7
Turbod
Turbod's Avatar
Drives: 2014 E84 X1 35i M Sport
FYI it is a inline 6 not a v6.
2011 E92 335i | 11.7@125 SOLD
2017 Camaro SS | 12.7@114 SOLD
2019 Audi TT RS | 10.5@130 SOLD
2020 F97 X3M | 11.0@123
2023 G80 M3 xDrive
      10-12-2018, 05:48 PM   #8
mcdanielvzw
mcdanielvzw's Avatar
231
His fingers just lost connection to the brain (happens to me too) - He has inline 6 at the end of the post.
2021 X3 M40i Sonnenstein metallic - JB4, LCI lights, 50th anniv badges
Wifey - 2021 X3 M40i Phytonic Blue - JB4, LCI lights
Selling - 2014 X1 xDrive 35i - JB4, VRSF DP / Charge Pipe https://shorturl.at/cerxH
About to sell 2016 550i M Sport - Arm DP, Arm Front-Facing Intake
Sold - 2009 328i - Stock, 195,000 running strong.
Turbod399.50
      10-12-2018, 10:45 PM   #9
MNX135I
Drives: X1 35I
Thanks for all the great advice!
      10-13-2018, 04:32 AM   #10
mcdanielvzw
231
Enjoy the 35i. Get a metal charge pipe (VSRF is fine), if you want more fun get JB4 (or other tune) and a downpipe ("fun" install). Tuned, the car is faster than many stock american muscle cars. I've seen the looks from camaro and other owners as I accelerate quicker from a light. It resembles "WTF WAS THAT"
      10-15-2018, 09:41 AM   #11
SharpAndCunning
Drives: 2014 X1 35i
VSRF might be fine, but the ARM motorsports one is cheaper, and the customer service is great!
      10-23-2018, 06:55 AM   #12
MNX135I
Drives: X1 35I
Just had to replace my oil filter housing gasket along with several other items. $1000 for the gasket repair, another $1000 for tension pulley, radiator flush, oil change, new belts, new plugs, and some other misc items. My 2014 X1 35i has 68k miles
      10-23-2018, 01:19 PM   #13
Gamb1t
Gamb1t's Avatar
Walnut blasting used to be the rage with N54 crowd. Is it still trendy with N55s?
Apart from the N55 block, I think everything that applies to the x28i applies to x35i too. Well OK the 8spd vs 6spd tranny. I think they have similar service intervals.
      10-23-2018, 01:26 PM   #14
Turbod
Turbod's Avatar
N54's are done every 30,000 - 40,000 miles. I had my N55 done at 50,000 and it didn't need it. I would wait until at least 85,000 before doing it. I personally will wait until 100,000 before I do it on the X1.
2023 G80 M3 xDrive
      11-07-2018, 11:38 AM   #15
SharpAndCunning
Drives: 2014 X1 35i
Thats crazy talk! How is the gasket repair $1000!? Another $1000 for basic maintenance things?!
      11-09-2018, 09:40 AM   #16
LevinBR
Drives: 2013 BMW X1 xDrive 35i
The gasket itself is cheap ($10 aftermarket, $30 BMW). The high price comes from labor, as much of the engine needs to come apart to replace this (not to mention it's messy).
Before I bought my car (used with 60k miles), I had BMW perform a pre-purchase inspection. A leaking oil filter housing gasket was all they found and they quoted the repair at ~ $950 . I had the seller (Mercedes dealer) replace it before sale.
      11-09-2018, 10:10 AM   #17
Kevman
Kevman's Avatar
45
Drives: 2019 BMW X3 x30i
I just had my airbag recall completed, so I let them change the oil while it was there. They called and said the oil filter housing gasket needed to be replaced, quoted me $750. I told them no thanks, the car is parked in the same spot every night and has never leaked a drop of oil. And the maintenance minder has never shown anything in the entire life of the car but 100% full. What a scam because alot of people would just say yes, go ahead.
      11-11-2018, 09:58 PM   #18
blackx1x35
Drives: 2014 X1 xdrive35i
I did transfer case, diff, coolant flush at 40k. Oil changes every 8 or so.
