      04-27-2018, 10:54 AM   #1
LLZ
England
Drives: X1 Xdrive 18d M sport
PDC Fault
Hi
I know there are loads of posts about PDC issues - it seems a common fault - but none seem to really cover my problems.
So the PDC fault warning came up on my dash but the sensors (rear only) still seemed to be work on & off & the warning was intermittent.
Its pretty much permanent now, so PDC fault on the dash on start up and in the BC when checked. It worked briefly today - but other than that there is nothing when i put the car in reverse & get close to things. This also means there is no clicking or pulsing from the sensors as it just seems to kill the system.
Unit is bone dry, connections look fine, no corrosion & the board looks OK to me.
Seems diagnostics is the next step unless anyone has any suggestions?
thanks in advance
Tags
pdc, pdc problem
