06-09-2017, 02:17 AM | #1 |
Rep 10
Need advise before buying
I'm looking to buy a 2014 BMW X1 xDrive28i is there something in particular I need to keep an eye out for when doing the test drive and inspection?
06-09-2017, 12:54 PM | #2 |
Rep 27
The X1's weak point is the AWD transmission - ensure matched tires on front and back. This failure is rare.
The N20 is generally a reliable engine. Trouble spots are electric water pump, and timing chain. Imminent pump failure is detected by engine fans cycling on high. Timing chain failure can be detected by a whining at the front of the engine. There was a design change in 2015 to address this failure mode. If this failure happens, it's expensive, which is why there is internet visibility - however not as common as it seems. Otherwise, not much to be concerned with. |
06-20-2017, 01:12 AM | #3 |
Rep 10
Thank you for the reply, I am now the ahppy owenr of one (attached pics) I got a couple of things to work on like the remote can be a lil crazy at times, getting another key, replacing the front bumper with Msport one also projectors and a reverse camera
06-20-2017, 10:23 AM | #5 |
Rep 89
Grats.
Mileage and options? Did you try looking for one with M Sports package?
2013 X1 x35i M Sport
Past: 2011 Mazda CX7 AWD Sport | 2004 BMW 330i ZSP/ZPP | 2008 Hummer H3 | 2005 Honda Civic VTi | 1997 Honda Civic ESi | 1996 Nissan Sentra SS EXi |
