      08-31-2016, 09:24 AM   #1
Njerts
Drives: x3 m40i
Any advice on rotors?
I can't believe my rotors are so messed up at 45000km
Deep grooves and vibrate at hard braking.
Is it worthwhile to go aftermarket or should I give OEM another chance?
Any advice will be appreciated.
      08-31-2016, 09:58 AM   #2
kiloTHREE
Drives: '13 xDrive28i
I've had excellent success with Zimmerman or Brembo, make sure to get painted/coated hats.
FYI BMW OEM rotors are made by zimmerman plus the bmw stampings.
Do you press hard on your brakes after you come to a stop or your pads never embedded properly in the first place?
      08-31-2016, 10:55 AM   #3
Njerts
Drives: x3 m40i
Thanks for the info.
I do not pay particular attention to how I use brakes.
After coming to a stop I apply just enough pressure to hold position.
If I am doing it wrong, I have been doing it wrong for 40 years☹️
All my previous vehicles got through at least 2 sets of pads before I had to change rotors.
I did not go through an embed procedure though. Just took it easy for the first 1000 km.
      09-01-2016, 09:07 AM   #4
X1Denver
niner
Drives: 13 X1 Alpine Xdrive35i M
https://www.ecstuning.com/BMW-E84-X1...raking/Rotors/
they have lots of options...including the Z4 rotors with aluminum hats......
Both BMWs I have owned and most audis have grooved rotors really quick. its the lip that you should see if they need replaced.
      09-01-2016, 10:03 AM   #5
Njerts
Drives: x3 m40i
Is stotted or cross drilled worth getting for a daily driver?
      09-01-2016, 11:00 AM   #6
LevinBR
Drives: 2013 BMW X1 xDrive 35i
Zimmermann "coat z" rotors are excellent. They have a coating which prevents rusting (which has occurred on all of my BMW oem rotors). The quality is great, and they are made in Germany
      09-01-2016, 11:11 AM   #7
LevinBR
Nope, and you'll get better longevity with solid, vented rotors.
      09-01-2016, 11:17 AM   #8
vstolpner
Drives: 2019 F39 X2 m35i
Check this out, will explain why you would want one over the other
https://youtu.be/78wbht355R8
      09-02-2016, 06:47 PM   #9
SharpAndCunning
Drives: 2014 X1 35i
i would just buy autozone replacement vented rotors.
      09-02-2016, 07:14 PM   #10
Mtpisgah
Drives: 2010 WRX & 2013 X1
I bought drilled and slotted when I replaced the front rotors. While I do drive aggressively in the mountains almost every weekend on the way to mtb, I will be honest and say they just look better.
      09-02-2016, 08:16 PM   #11
Njerts
Drives: x3 m40i
What brand?
      09-02-2016, 10:48 PM   #12
Teutonic
Teutonic's Avatar
Are you washing the vehicle right away after a hardcore driving?
I will go for OEM installed by the dealer. No headaches.
      09-02-2016, 11:33 PM   #13
Njerts
Drives: x3 m40i
I am aware to not put water on the hot brakes, if that is what you mean.
I am scared to ask what the dealer will charge me.
I have always done my own brakes.
      09-03-2016, 12:10 AM   #14
Teutonic
Teutonic's Avatar
Yes, I was referring to that.
Why don't you go and ask? or give them a call. If it doesn't make sense do it yourself.
I am the opposite, I don't touch the brakes and other stuff, dealer does it. I don't have the time or the tools.
Ask for the dust free ones. Good luck!
      09-03-2016, 01:40 AM   #15
Njerts
Drives: x3 m40i
Thanks, I will consider your suggestion.
      09-06-2016, 08:32 PM   #16
Mtpisgah
What brand?
Centric Stoptech
http://www.partsgeek.com/gbproducts/...ad=47433964212
The link may not be the exact rotor because I have a 28, but close enough.
      09-06-2016, 09:04 PM   #17
Njerts
Drives: x3 m40i
Centric Stoptech
Tx,
Those looks nice
      11-27-2016, 10:07 PM   #18
Njerts
Drives: x3 m40i
Just a followup,
It seems like my rotors are smoothing out, I still have some grooves but not as bad as when I started this thread.
I did ask the dealer what it will cost me for new pads and rotors on all four corners, I nearly had a stroke when he told me $1830.00
I will definitely do it my self at some point, the hardware will probably be around $300
      11-27-2016, 11:19 PM   #19
Gamb1t
Gamb1t's Avatar
Just a followup,
Notice your in Vancouver. Have thought about going to one of the many indie bmw shops? I heard Nixon auto in Burnaby is quite good.... They are quite busy though. Is your out by the Fraser valley, there's Anderson Autohaus. Owner is part of bmw club and races.
      11-27-2016, 11:22 PM   #20
Njerts
Drives: x3 m40i
Thanks,
I will shop around now that I have more time.
      11-28-2016, 04:52 PM   #21
DUI Elite
///M at Heart
DUI Elite's Avatar
90
Drives: 06 SGM E90, 15 BSM E84
Just go with centric (aka stoptech) blank rotors.
Don't bother with drilled or slotted rotors. They're a visual mod more than anything. They will crack as soon as you get any significant amount of heat in them.
      11-28-2016, 06:30 PM   #22
Njerts
Drives: x3 m40i
I think I will. I have always done my own brakes and it is not difficult at all.
I got a nice socket set with a torque wrench on black Friday.
But my brakes feels really good now, hopefully they will last till summer. It is so much better working on a car if you are not freezing.
I will start shopping for part in the mean time.
