08-24-2016, 12:35 AM | #1 |
Rep 254
Aftermarket intake question
hey guys,
is our X1 35i intake the same as the e90/e92 n55 intakes? It seems like it is per the realoem website... http://www.realoem.com/bmw/enUS/show...80#13717599282 Reason i am asking is I am thinking about the GruppeM intake... There's no version specifically for the X1 but I hope the E90 version can fit. http://www.xposed.com.au/bmw-3-serie...-e93-335i.html Yes, it is expensive but the craftmanship is amazing Anyone know a place that sell this intake for less? |
08-24-2016, 09:06 AM | #2 |
44
Rep 209
X1 N55 intake is same as E90 N55's. The piping and the intake ducts are the same. There is no way I would pay that much for an intake! It is a great design and looks great, but who looks under the hood of an X1?
Buy a used Burger, Injen or AFE. I use BMS intake and clean my filter often and clean the MAF often. The sound is nice with the intake and it is a 10 minute switch back to stock if needed. I also use the E90 AFE intake scoops to help draw more air into the intake tract. I am sure it will fit, but the cost is crazy. Check out the Eventuri website, these guys have a unique design and maybe they can make an N55 E series intake for us!
X1 35i M-Sport, Pure Stage 2 turbo w/ inlet and outlet, 7in intercooler, Fuel-It PI and pump, Jb4 w/MHD, XHP, custom catless exhaust, KW V1, Volk's and everything else...!
08-24-2016, 01:32 PM | #4 |
///M at Heart
90
Rep 1,954
Thats the most expensive intake ive ever seen for a non-m bmw. Im actually mildly impressed that that is a product.
That being said, I think there are better options (as others have said). +1 for using e90 air scoops. I added cyba scoops and k&n drop in filter to my X1. |
08-24-2016, 02:02 PM | #5 | |
Rep 1,399
08-24-2016, 02:45 PM | #6 |
Rep 137
I would be weary about the efficacy of an intake on an engine equipped with a turbocharger! No matter what you do to the air coming in, it enters the turbocharger at a controlled rate. There, it is compressed and heated up before finally entering the engine. In other words, the turbo will cancel out any effects from an improved intake. For naturally aspirated engines, however, I do think intake improvements are a worthwhile investment.
I too was interested in a cold air intake for my X1 35i, but after doing some research, it doesn't make mechanical sense - especially not for the price of the one you are looking at! Just food for thought. |
08-24-2016, 03:48 PM | #7 |
Unllicensed
29
Rep 444
*wary You could get a Dinan tune for less $. That's absurd, but then, so's the price of a download tune. More air in, more HP, regardless of NA or FI.
08-24-2016, 06:52 PM | #8 |
///M at Heart
90
Rep 1,954
I measured the length of the holes for the E90 fitment (for the innermost screw) and drilled a hole through the plastic covering on the E84 to have the exact same fitment:
(yes I painted them white) I like the grayscale theme if you can't tell from the pic of my E90 in my sig
| 3-IM | AA Headers | Eurocharged Stage-3 | BMW PI | |
09-01-2016, 09:02 AM | #9 | |
niner
16
Rep 148
This is correct. Car manufactures know what air cleaner and box to use. If you upgrade your turbo or compressor wheel then you would want a larger filter assymbly. The turbo compression suction is always limited to rpms of the turbine wheel and the compressor wheel fins. As opposed to vacuum suction of a NA engine. Your stock airbox is made for your OEM turbo. That being said, a straight 6 of a BMW always sounds dope with a fancy CAI. |
