05-18-2016, 10:03 AM | #1 |
Rep 254
Xdrive35i mods
Hi,
I am planning to buy the a couple of mods for my BMW X1 Xdrive35i. Could you guys let me know if I am buying the right stuff? 1). JB4-Type B harness + USB cable 2). ER chargepipe 3). Catless downpipe (n54 tuning?) 4). ER Intercooler 5). Pure Stage 2 Turbo 6). N55 PURE High Flow Inlet Pipe 7). N55 Diverter Upgrade DV(Plus) I will probably do item 1-3 first then 4-7 later on when budget allows. Anything I should change on my to buy list? My target is to have around 450 whp on pump gas (94 octane) running Map 2 with everything done. Is that realistic? Thanks, |
05-18-2016, 10:42 AM | #2 |
Rep 2,411
I'd so some suspension work too while I was at it. But as far as power mods go, that's a nice little list...
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
hooligan_G016523.00 |
05-18-2016, 10:47 AM | #3 |
Rep 1,399
My list is like this...
Dinan stage 2 -done BMS intake- done Black Grills -done Jb4 in place of dinan -(possibly already have it) VRSF CP -(on the way) Suspension setup of some kind-cant decide on setup 19x9/10 concave setup-haven't decided on brand yet That's it. I don't need 450 awhp, just a fun car that looks good. I don't have a track near me so it's pointless to go stupid with it. |
05-18-2016, 02:21 PM | #5 |
44
Rep 209
Things I'd change...
Perform the Iso mod on the Jb4, enable the newest firmware with timing ability. Get Rev 3 Bluetooth kit for Jb4 and the app, you'll use this set up all the time and never use a laptop for logs etc. You'll need the Pure install kit. You'll benefit from new tmap sensor, changes the jb4 maps for the Pure stg 2 and holds higher boost than regular Jb4 maps for n55. Look into Alpina Trans flash I'd install Oil catch can before cranking the boost and new colder spark plugs with .022 gap I have plenty of other thoughts and have been through a bunch of trial and error getting my car to run predictably with the Pure stage 2. It's a beast for sure, but can be finicky...lots of variables come into play with increased boost |
05-18-2016, 05:54 PM | #7 | |
Rep 2,359
05-18-2016, 10:12 PM | #8 |
Rep 1,399
05-19-2016, 12:03 AM | #9 |
Rep 2,359
If you bought your car from Downtown Mercedes (which I believe you do) then be careful, the rear tire (at least that one) was fixed. Just so you don't have an unpleasant surprise.
I was looking for a second X1 to buy as a DD for me but couldn't find a low mileage one or new. I looked to buy that one too but the air intake turned me down. I am not saying that is something wrong, but I am personally not comfortable in buying a tuned car. |
05-19-2016, 12:03 AM | #10 | ||
Rep 254
http://www.n54tuning.com/e-series-n55-jb4.html thanks! |
05-19-2016, 06:25 AM | #11 | |
Rep 1,399
You're in Calgary then, have you modded your own? |
05-19-2016, 09:38 AM | #12 |
44
Rep 209
The link is correct for Jb4 and you need type B harness.
If your only going to run pump and 14psi, I wouldn't even consider the Pure stage 2 and all the work and cost that go into the install. Just go catless and get the jb4 working right and start to experiment with higher boost levels on the stock turbo. Do your Jb4 research over on n54tech website and read up on the Iso changes that need to be made to the Jb4 board and firmware. |
05-19-2016, 11:28 PM | #13 | |
Rep 2,359
05-20-2016, 12:42 AM | #14 | |
Rep 254
http://www.n54tuning.com/e-series-n55-jb4.html is it on the n54tuning webpage? |
05-20-2016, 08:51 AM | #15 | |
44
Rep 209
Here it is with free shipping and drop ships direct from BMS, saves the $14 shipping found at all other retailers.. http://www.**********s.com/BMS-JB4-Bluetooth-Kit.htm The bluetooth does not connect with the Jb4 software that you may have loaded on a laptop(still need usb cable), but the mobile does everything and more than the laptop software. Logging, firmware updates, graphs, setting changes etc.
X1 35i M-Sport, Pure Stage 2 turbo w/ inlet and outlet, 7in intercooler, Fuel-It PI and pump, Jb4 w/MHD, XHP, custom catless exhaust, KW V1, Volk's and everything else...!
05-20-2016, 10:07 PM | #16 | |
Rep 2,411
OK...good luck.
05-22-2016, 02:49 AM | #17 |
That was a hell of a thing...
22
Rep 168
I agree with Apex there. You need to address the shortcomings of the X1 chassis. It is excellent, but it can be transformed into a really great handling rig for not a lot of dough.
Doesn't make a lot of sense to push all that power without sharpening up the handling. |
05-25-2016, 02:08 AM | #18 |
Rep 10,509
I would personally do the FMIC before the downpipe
Also, I would switch to wider tires (maybe a 255 wide square setup) as part of the initial mods Personally, I think there starts to be a reliability question mark if you go past full bolt on and plan to really drive the car hard, so it seems worth it to consider overall goals and the platform overall before going off the deep end into turbo swaps, suspension mods etc. As an example, I can't help but notice that C5 z06 are getting pretty cheap these days... Why not keep the X1 relatively stock and just add on a Z06 to the stable..... |
06-08-2016, 03:22 PM | #19 |
Rep 254
hey guys, i am about to be ready to buy all these mods:
1). JB4-Type B harness + USB cable 2). ER chargepipe 3). Catless downpipe (n54 tuning) 4). ER competition FMIC 5). Pure Stage 2 Turbo 6). N55 PURE High Flow Inlet Pipe 7). N55 Diverter Upgrade DV(Plus) Does it make sense to have a shop install these all at once or FBO first then the turbo? What's the estimate on the number of hours needed to install everything? thanks! |
06-08-2016, 07:10 PM | #20 |
44
Rep 209
Do 1 and 2 first, work our how to setup the jb4 and test for a while.... then 3-7 can be done at the same time.
Turbo swap is usually quoted at 8hrs. You need the turbo install kit with the flange nuts and o-rings etc and bmw coolant, distilled water etc for turbo swap. What's the goal with the build? High horsepower or tracks duty or what... You'll need to keep an eye on misfires and fuel pump issues or enough octane for the boost levels |
06-08-2016, 09:21 PM | #21 | |
Rep 254
06-08-2016, 09:47 PM | #22 |
44
Rep 209
Get the n20 tmap sensor and upgrade the jb4 to use the new maps. Stick with map 1, 16psi for daily driving. Pulls hard to redline on 93 pump no problem. The other jb4 maps drop boost in upper rpm range
