BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      02-25-2008, 03:35 AM   #1
Leg
Drives: E92 M3 V8 Alpine White
Breyton GTS Race wheel weights
Found out the weights for the Breyton GTS Race wheel:
19 inch fronts 9.0kg (19.84lbs)
19 inch rears 9.5kg (20.94lbs)
20 inch fronts 10kg (22.04lbs)
20 inch rears 11kg (24.25lbs)
Nice! That is lower than BBS CHs and LMs.
Direct from Breyton in Germany (Crikey my German is rusty!!). They told me they had gone all out on this one to reduce weight as much as possible. Looks like they managed it.
Set of those with Michelins on (same as OEM tyres) should do me fine. Question is, silver, gunmetal, black or black with a white or polished lip. Narrowing it down step by step though!!
Anyone wants to check, this is the number +49 (0) 40 789 179 0
      02-25-2008, 07:10 AM   #2
rvacha
rvacha's Avatar
Drives: '08 E92 M3
2008 E92 M3  [0.00]
Hum... lighter than I was guessing. Thanks, a very helpful post
'16 F30 340i xDrive 6MT Melbourne/Black
'08 E92 M3 6MT Jerez/Speed Cloth
'18 F80 M3 6MT SO/CSAT
      02-25-2008, 07:22 AM   #3
Epacy
Reincarnated
Epacy's Avatar
245
Drives: 02 Maxima SE
2008 M3  [0.00]
Not bad weight at all. You can get them with a lip?
      02-25-2008, 09:06 AM   #4
edlms
edlms's Avatar
10
Drives: E92 M3
good weight.
but from the related posts, the front offsets are close enough but the rear offsets for the 19"s aren't suitable for the e92 m3 right?
      02-25-2008, 09:34 AM   #5
lucid
lucid's Avatar
Drives: E30 M3; Expedition
No way!!!! Wow, that's really low, considering they cost much less than the BBS wheels (tirerack quotes the Breyton's at $289 a piece available 4/1 with black finish only). Thanks for the info. When are you getting them? Can you please weigh them when you get them to verify the numbers?
      02-25-2008, 09:41 AM   #6
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
that's same as RSGT's, right?
      02-25-2008, 05:27 PM   #7
Leg
Those weights were quoted to me when I rang Breyton in Germany this morning. They are for the M3 specific ones due to be available at the end of March in Europe (dunno about the States, sorry).
They do not come with a lip as standard and would have to be sorted aftermarket. Im thinking black and having a white lip painted on to go with my AW M3. Either that or just plain silver.
      02-25-2008, 06:09 PM   #8
OC ///M
Dr. Octagon
OC ///M's Avatar
Drives: Moonstone e92 M3
What et are they setting you up with Leg?
OC ///M
2013 E92 M3 Individual
Sold: 2011 E92 M3 SSII | Sold: 2008 E92 M3 SSII | Into a Wall: 2008 E92 M3 SSII | Sold: 2007 E92 335i JB
      03-07-2008, 09:16 PM   #9
Alvinlun
Drives: E92M3 and Z33
what do you think of the quality of this wheel??
      03-22-2008, 11:01 PM   #10
asaulo1
asaulo1's Avatar
38
Drives: 2008 M3 Coupe, alp white
tire rack has these for the E92 and it seems like a good price... little less than $300 per wheel..... I wonder if the center bore will be a direct fit for the E92 M3 as opposed to using hub centric rings...
      03-22-2008, 11:32 PM   #11
OzStriker
OzStriker's Avatar
Australia
61
Drives: Ford Falcon Ute, Ducati 1198S
Here are some shots of the matt grey...Please can someone Photoshop these onto an AW??? Perhaps the middle photo with the rims in the shade will fit?
Pictures thanks to mds82 on this thread:
http://www.e90post.com/forums/showthread.php?t=126057
BMW E92 M3 6MT, G-Power SKII supercharged, custom exhaust with 100 cell cats and Remus Sport mufflers, Brembo 380mm BBK, BMW Performance steering wheel, LUX H8 angel eyes, CF CSL boot, Hamann CF diffuser, Vorsteiner CF lip, CF grilles, CF gills, CF bonnet vents, BMW Performance stripes, RAC RG63 wheels, Eibach lowering springs, camber modifications.
      03-24-2008, 11:43 AM   #12
asaulo1
asaulo1's Avatar
38
not really feeling the 20s though... maybe 19s.... what do you guys think?
      04-06-2008, 12:22 AM   #13
franciscosss
franciscosss's Avatar
10
Drives: 2008 328i Sedan
2008 328i  [0.00]
19x8.5
$289
Offset: +30mm
Bolt Pattern: 5-120
Rec. Tire Size: 235/35-19
**Lightweight: 26.5lbs.**
The above information is from TireRack. They're also made in China, not Germany...
      04-06-2008, 06:47 AM   #14
Leg
Yeah we had this discussion on another thread, seems that the weights given to me by Breyton werent accurate. However, they weigh about the same as BBS CHs (Tirerack quote them at 26.1lbs) so they are still relatively light compared to most wheels. Certainly absolutely fine for road wheels as I ran 19 inch 8.5 BBS CHs on my TT for 2 years and they were absolutely fine.
E92 M3, Breyton GTS 19s, black and carbon all over
Factory Mini John Cooper Works 211bhp
MK Indy R track car (road legal) 300bhp+ per ton, sequential box
VW Tiguan 4x4
      04-06-2008, 11:20 AM   #15
Epacy
Reincarnated
Epacy's Avatar
245
2008 M3  [0.00]
They are also approx the same weight as the stock 19s.
      04-06-2008, 11:27 AM   #16
Deathboy
Drives: GT4
Sweet!
      04-09-2008, 07:55 PM   #17
hellrotm
Drives: F80
Originally Posted by franciscosss View Post
19x8.5
$289
Offset: +30mm
Bolt Pattern: 5-120
Those are the weights of the GTS
The GTS-R are all new, lightweight.
Gill from tirerack posted the 18 inch weight on 1addicts. Not sure about the 19/20 inch weights. But the 18 inch weights are impressive.
18x7.5" 17.2 lbs. $279 per wheel* (Matte Grey and Black)
18x8.5" 17.6 lbs. $289 per wheel* (Matte Grey and Black)
I don't think the GTS-R lightweight Breytons are on the tirerack site yet.
They are not available until early May.
      04-12-2008, 09:38 PM   #18
lucid
lucid's Avatar
17 lbs 18" wheels at $290 each? Sounds too good to be true honestly. I'll be keeping an eye out for these...
      04-14-2008, 03:41 AM   #19
hellrotm
Drives: F80
I actually saw it over on the 1addicts board.
Gill from tirerack was posting the new wheels for 135i fitment.
He says they should arrive in May.
http://www.1addicts.com/forums/showthread.php?t=6452
      04-14-2008, 04:07 AM   #20
Nucking Futs!
Nucking Futs!'s Avatar
Drives: E70 X5 M
2013 BMW X5 M  [0.00]
Yeah, saw that on 1addicts also but Gill didn't say if the weight info he posted was weighed & verified by Tire Rack or if that's the info Breyton provided Tire Rack. Based on Breyton's track record of providing weight info, I'll believe it when an independent source (such as Tire Rack) weighs them. Gill also said those are the only staggered setup they'll be carrying & not sure if Tire Rack will carry the 19" & 20" versions in the future. Then again I'm not sure if he's referring to the 1-series fitment only or in general.
'13 E70 S63B44A
'17 95B GTS
      04-14-2008, 04:34 AM   #21
enigma
Drives: E92 M3 and Elise
I always thought Breyton was a "bling" dealer. Not something I would associate with performance. They just seemed more for show than go. The best example being the 20" sizes.
On the other hand my 18x9.5" track rims (front and rear) should be on a shipping truck somwhere. Estimated weight of 20lbs
Manual gearboxes, the rotary dial of cars.
      04-16-2008, 06:59 AM   #22
Leg
Just got this email from Breyton.
Hi Richard,
thank you for your response.
The look of the GTS-R is not so much different than the GTS. The same look to
the wheel will be kept but the weight is reduced significantly. The backside of the
spokes will be a different shape and the wheel will have a red circle behind the spokes.
Pictures are not yet available but will come soon.
We will start with 18” sizes for Mini and 1-series application. Maybe bigger sizes will
follow but we did not finally decide about this yet.
We expect that GTS-R will become available in the UK approx. June/July.
Hoping to have served you.
Best regards
ppa. Reinhard Kratzmann
Senior Sales Manager
Georg Grotjahn (GmbH & Co. KG)
Hans-Henny-Jahnn-Weg 35
D-22085 Hamburg
Tel.: +49 (0) 40 789 179 17
Fax: +49 (0) 40 789 179 18
E-Mail: reinhard.kratzmann@georg-grotjahn.com
Web: http://www.georg-grotjahn.com ; http://www.breyton-export.com
VW Tiguan 4x4
m3post
