BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Wheels + Tires Sponsored by The Tire Rack
KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK!
      02-24-2008, 06:51 AM   #1
eolot
eolot's Avatar
10
Drives: 320di
Most aggressive ET for M3 E92 ?
What is the most aggressive ET with 8,5x19 and 9,5x19 or 10,0x19 for a M3 e92 without rubbing issues? Thank you for all the answers.
      02-24-2008, 11:42 AM   #2
///MML
///MML's Avatar
Drives: e92 M3
Usually there is a 1/2" to play with before rub problems. The stock ET is F/29, R/23. You could do an ET offset of approx F/15, R/10 and be ok assuming OEM tires/rim specs.
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
      02-25-2008, 02:32 PM   #3
eolot
eolot's Avatar
10
Drives: 320di
You mean that i can get 8,5x19 et 08 front and 9,5x19 et 19 rear?
Are you sure?
      02-26-2008, 09:31 PM   #4
///MML
///MML's Avatar
Drives: e92 M3
a 08 ET will be pushing it. That's 21mm the front wheel will be pushed out toward the fender, probably too aggressive. 19 ET should be no problem.
      02-27-2008, 06:13 AM   #5
eolot
eolot's Avatar
10
Drives: 320di
et19 is more aggressive than et21.
Are you sure of what you' ve said?
      03-03-2008, 04:00 AM   #6
eolot
eolot's Avatar
10
Drives: 320di
Any more answer?
Nobody can help me?
      03-08-2008, 07:36 PM   #7
///MML
///MML's Avatar
Drives: e92 M3
yes i'm sure. 29 - 8 = 21
      03-10-2008, 02:37 AM   #8
eolot
eolot's Avatar
10
Drives: 320di
An e92 M3 with originals M6 rims 8,5x19 ET12 and 9,5x19 ET17
      03-12-2008, 12:17 PM   #9
drivrswntd
drivrswntd's Avatar
15
Drives: 330ci
So if I am looking at a set of BBS LM-R's and they are 19x8.5 et 13 front and 19x9.5 et 25 rear then they should fit?
      03-12-2008, 02:02 PM   #10
ExclusiveAlloysE90
ExclusiveAlloysE90's Avatar
Drives: Bee M Double U 335i 4dr
2007 335i Sedan  [0.00]
Because the car just arrived on the US shores and no one has any idea of the exact offset aftermarket wheels will be needed for fitment on this car, I'd be patient and wait to see exactly what will fit. You say you want the most aggressive fitment without rubbing which is fine, but you need to bear in mind the brand of tire that you will be using will probably come into play as well. Each and every single tire manufacturer have different size sidewalls even though the size specs are the same. This will affect how "aggressive" you can go as well.
      03-12-2008, 02:52 PM   #11
drivrswntd
drivrswntd's Avatar
15
Drives: 330ci
Have you seen the Ericsson M480 LM-R Fitment? They are calling out specs of 20x9 et8 and 20x10 et 18 on the new M
      03-18-2008, 11:28 AM   #12
ase2dais
//Mdicted
ase2dais's Avatar
Drives: a Cop Magnet
WOW! nice wheels, very logical choice for me if/when I get the new Ms.
You did good!
      03-18-2008, 02:03 PM   #13
nico335
Guest
n/a
Drives:
would a 19 x 10.5 25 offset fit on the rear of an E92 M3? without rubbing...
      03-20-2008, 11:37 AM   #14
Blip Bavarian
salivator
Blip Bavarian's Avatar
Drives: 16 GT4, 14 X5 V8 & 91 E30 LS1
if you have rubbing probelems, can they be fixed with a simple set of spacers? What are the downsides/concerns when using spacers?
      03-20-2008, 11:43 AM   #15
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
spacers if you are rubbing? does that make the wheels stick out more and cause more rubbing? you probably need to shave the offset a little, not spacers
      03-27-2008, 06:18 PM   #16
skierman64
skierman64's Avatar
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
He's right, spacers push the wheels out toward the fenders. You're going the wrong way if you're using spacers.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
      03-28-2008, 01:49 PM   #17
hawkeye-se
Drives: '09 JB Coupe
Unless it is rubbing the strut.
      03-28-2008, 09:13 PM   #18
m3forever
m3forever's Avatar
American Samoa
26
Drives: 2010 335D
Please enlighten me what does et stand for and mean? i searched but came up with this http://en.wikipedia.org/wiki/E.T._the_Extra-Terrestrial..
2010 BMW 335D
2006 YAMAHA R6
2004 Acura TL Aspec (Sold)
2003 BMW E46M3 (Sold)
      03-30-2008, 10:47 AM   #19
skierman64
skierman64's Avatar
2011 BMW Z4  [0.00]
ET is offset. Tirerack.com has a good explaination on this.
      03-30-2008, 11:10 AM   #20
GregW / Oregon
Commander-In-Chief
2196
Drives: 2023 M2 Coupe, 2020 GLE 450
ET
Abbreviation for the German "Einpresstiefe", I believe.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      03-30-2008, 11:19 AM   #21
skierman64
skierman64's Avatar
2011 BMW Z4  [0.00]
Here's the article. http://www.tirerack.com/wheels/tech/...urrentpage=106
      03-30-2008, 09:46 PM   #22
m3forever
m3forever's Avatar
American Samoa
26
Drives: 2010 335D
thanks guys
2010 BMW 335D
2006 YAMAHA R6
m3post
