Go Back   XBimmers | BMW X1 Forum > BMW X1 Forums > Classifieds: Members for sale-trade-wanted
      08-05-2015, 09:48 AM   #1
PrematureApex
WTB: BMW X1 N55 OE Axle Back Exhaust
Looking for a stock axleback!
Thanks!
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs)
'14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat)
'08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat)
      09-12-2015, 09:58 AM   #2
PrematureApex
Still looking!
      09-22-2015, 07:40 PM   #3
PrematureApex
Someone has to have a muffler!
      09-23-2015, 02:23 PM   #4
mwtrogus
Drives: 2014 X1 35i
I will run my stock muffler over the winter months.... or I'd sell it to you.
Ive been running an Active Auto Gen1(from a 135) sounds so mean... I'd just look for a used one and have a muffler shop make it fit, it doesn't need much to bolt right up. It drones at highway speeds and partial throttle
      09-23-2015, 06:16 PM   #5
PrematureApex
Is the rest of your exhaust stock? And still drones?
      09-23-2015, 09:32 PM   #6
mwtrogus
Drives: 2014 X1 35i
I have catless downpipe and stock mids... I saw your in Philly area. I'm not far from you, near Reading!
      09-23-2015, 09:37 PM   #7
PrematureApex
Oh nice. Don't see to many of these things around. That will make it easy when you decide to sell me your stock muffler!
Do you swap the DP back and forth for inspection? Or do you time it perfectly, and go in with only 1 readiness not done? Can't believe there's no rear O2 fix yet...
      09-23-2015, 09:46 PM   #8
mwtrogus
Drives: 2014 X1 35i
I have to swap the catless downpipe out and then drive cycle the car so I can pass PA inspection... its a pain in the butt! The catless makes the exhaust quite a bit louder and you can really hear the turbo. I'll do the Pure stage 2 in late winter if nothing better comes out before then... I do need help on the suspension side so we should get together
      09-23-2015, 09:56 PM   #9
PrematureApex
Definitely.
If you want to give it a try...PA allows one readiness monitor to be incomplete and still pass inspection. The rear O2 is normally the last monitor/test to finish, as it requires a lot of cruising and multiple starts before it will throw the light.
You can reset the ECU, drive around with a scanner plugged in (following routines similar to the published drive cycles needed to complete each test)...and when you get all but the O2 test cleared, park it at your inspection place to have tested. Less of a PITA than swapping the DP (really that much harder an AWD vs. a RWD?)
Hopefully those guys on the E90 forums (Canadian I think?) getting close to a cheap fix come through....
      09-23-2015, 10:04 PM   #10
mwtrogus
Drives: 2014 X1 35i
Definitely.
The evap clears and then the O2 trips the light right away. I used a tester for a while before my inspection to see if I could beat the system and pass with 1 in a not ready state, but it just doesn't work. My buddy is my inspection guy too and it's just easier to swap the cat back in and then back out and bang it out in one day.
I know Jack from Miami on the Facebook E84 forum was going to make exhausts systems soon so maybe we can get him motivated with a few buyers lined up.
      10-10-2015, 07:44 AM   #11
PrematureApex
Bump...
And mwtrogus, are you able to swap the DP without dropping the subframe? How long does it normally take you?
      10-11-2015, 09:34 PM   #12
Mr_Jack
Drives: X1 35i M Sport
Bump...
You have to drop it about 25mm to get the stock one out. No biggy, should take roughly 1.5hrs.
I am waiting to build one for myself and see what it sounds like and whats involved before putting a price.
'15 E84 X1 35i M Sport
MPI DME Flash - K&N drop in - MPI Chargepipe - Oil T-stat valve - ETS 5" I/C - N54tuning 3.5" downpipe - catless mid section - Dinan 135i rear exhaust - Apex ARC8 18x9/10(255/295 tires) - H&R Sports - Bilstein B6's - F3x M Performance brakes
'02 E39 530i 624whp/558ft-lbs @23psi
      10-12-2015, 02:03 PM   #13
AWF87M2
AWF87M2's Avatar
827
you could always check with a salvage/junk yard.
Thanks!
      10-14-2015, 11:28 PM   #14
BeEmVe
Drives: '14 X1 x28i M-Sport
These guys might be able to get you what you need: http://mandmautosalvage.com
