Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls
      07-29-2015, 06:42 AM   #1
John dillinger
Drives: 2015 M4
Question tire pressure monitor
anyone else have their alert go off ? 45 miles on car and alert went off with tires showing 33 - 34 psi on all 4 …..
what r they supposed to be ??
      07-29-2015, 07:33 AM   #2
Vigilant
Vigilant's Avatar
Drives: Cautiously fast
Originally Posted by John dillinger
anyone else have their alert go off ? 45 miles on car and alert went off with tires showing 33 - 34 psi on all 4 Â…..
The TPMS should not alarm for those readings. Recheck the tire pressures with an electronic or manual pressure gauge.
Tire pressure from the factory on the PSS is listed at 32 PSI (cold).
Also...reset the TPMS through the I-Drive. If that doesn't work then touch base with your local SA. You should not be having issues at 45 miles into ownership.
2022 BSM G80 Comp X-drive
      08-01-2015, 10:26 PM   #3
parky1215
parky1215's Avatar
572
Drives: F90 M5C | G06 X6 M60i
I set cold tires at 32 psi.
On freeway, they go little bit over 35 psi.
f80post
