Pandora Car Alarm System
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      01-22-2015, 08:40 PM   #1
JDS
Drives: 2021 MBB F97 X3MC
Can Parking Assistant be Coded On?
I saw someone's order form on here and wondered if the 5DP parking assistant option can be coded, if you have all the cameras?
Is there any other hardware, switches required? Anyone have any insights? Perhaps it needs an FSC code?
James.
Drives: 2021 F97 X3MC LCI - Marina Bay Blue Metallic
Gone: 2019 G16 840i GC - Frozen Bluestone Metallic
Gone: 2018 F80 M3C - Sakhir II Orange Metallic
Gone: 2015 F80 M3 - Mineral Grey Metallic
      01-23-2015, 11:14 AM   #2
Zeroblade
Explodes on impact
Zeroblade's Avatar
Drives: 2006 Mazda3
Disclaimer: I do not own this car nor how its built
From the technical standpoint, likely it can be coded but need more than just cameras. Most critical is the proximity sensors on the bumpers and sides of the car that is also needed. Its those little circles you find especially just under the front side view cameras as an example. Cameras alone do not have the ability to sense the distance the car is to objects. I would also imagine there might be other systems and/or possible coding/parts needed - such as something that regulates how must throttle/brake to apply.
TLL - Yes it can be coded but will be incomplete without other critical systems/parts.
Yea... yea I got an M(azda)3.... <.<
*work in progress*
      01-23-2015, 11:28 AM   #3
JDS
Thanks. I have front and back parking distance control, plus the full camera package. I just am not sure how the system is activated so wasn't sure if there was any additional hardware required. I was thinking more along the lines of extra sensors or an initiation switch. I didn't think of a controller for the throttle/brake I do have DCT though which should make it easier.
Still too much uncertainty for me to give it a go
      01-23-2015, 11:30 AM   #4
Andrew115
Andrew115's Avatar
328
Drives: Silver Bullet
Would love to know the answer here. I also have all the options you listed and would like to try coding it on.
      01-23-2015, 12:08 PM   #5
JDS
Just watched a video on YouTube about how this works. The car basically only controls the steering, you have to provide manual throttle and brake input, so it is unlikely there is any required hardware there. That may suggest that there are extra motors required to drive the steering input however, but then again with the F80's electronic steering, this equipment could be accessed by the parking assist too, just needing software input.
I may try and add it tonight and see if it is recognized. I am not sure which ECUs I will need to VO code though, and I am not too keen on adding back in all my prior coding on a hunch.
Someone must have tried this...?
      01-23-2015, 04:20 PM   #6
crashtestdummy81
crashtestdummy81's Avatar
England
25
Drives: YMB F83
You would need to add the side sensors for this to work
      01-23-2015, 04:27 PM   #7
JDS
Thanks. Now where is that deflated smiley?
Almost talked myself into thinking this might actually work!!
      02-05-2015, 04:11 PM   #8
ChrisMT79
ChrisMT79's Avatar
Drives: 2015 F80 M3- Alpine White
Just taking a guess, but looking at the electrical diagram from the 7 series, it would appear both the side cameras (by the wheels) and the side camera control units would also be needed.
http://www.realoem.com/bmw/partgrp.d...43&hg=66&fg=05
      02-05-2015, 04:48 PM   #9
JDS
I have the side cameras, I believe, as part of whatever package they come with, but I think the sensors for parking assist might be slightly different and not necessarily purely optically based...
Can't remember where I heard or read that though...
      02-05-2015, 09:22 PM   #10
ChrisMT79
ChrisMT79's Avatar
You have different side cameras, and the ultrasonic sensors are different.
      02-05-2015, 09:26 PM   #11
JDS
Yes, thanks. I have pretty much given up on this one.
Don't really need it round here anyway. It's not like there is a shortage of parking. And being British, parallel parking is in our blood. We are born able to do it...
      12-09-2015, 01:27 AM   #12
DaBean
Sakhir Smurf
314
Drives: Plaid, F82 M4, E46 M3, Sequoia
2002 BMW X5 4.4i  [0.00]
2015 BMW M4  [0.00]
2004 BMW M3  [0.00]
Did anyone confirm whether this can be done or not?
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads
NASA NorCal Instructor
      12-23-2015, 03:51 PM   #13
sandwi54
sandwi54's Avatar
Drives: G07, F90
This cannot be done as two additional sensors in the front bumpers are needed.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD)
f80post
