06-06-2014, 04:46 PM | #1 |
Rep 153
TPMS Error
Is anyone experiencing issues with the TMS? the last 2 days only first thing in the morning my TPM alerts me of low tire pressure in the passenger side rear tire? After i reset the TPMS everything is fine. Also noticed there is nothing wrong with the tire. I know other BMW'S in the early 2000's had issues but i thought it had been resolved.
2021 MYLR (c), 2016 MB E350 (c),2018 MB E300 (r), 2019 AMG GT63s 4D (r),2018 MB E63S (r), 2018 911T (r), 2014 X5M (r), 2013 X1 35i (r),2011 M3 (r), 2010 328i (r), 2008 M3 (r),2005 330ci (r), 2004 Lotus Elise (r), 2004 X3 (r),2002 330ci (r), 2002 Hummer (r), 2002 MB G500(r), 2000 Z8 (r), 2000 323cic (r)
06-06-2014, 05:03 PM | #2 |
Rep 47
No but mine randomly gave me a TPMS Malfunction. I reset it and all is well (?) Not too comforting. It's been about 2 weeks, however, since that incident. And, like you, all 4 tires were at factory spec.
06-06-2014, 05:45 PM | #3 |
Rep 170
Came up for me once when I did a trip to Tahoe, but It was due to the change in temp..... I would check your psi in the tires when they are hot and then reset it and see what happens....
06-06-2014, 06:24 PM | #4 |
Rep 62
If it is reset when tires are hot, there is more liely to be a false alarm. For example, say fronts should be 35 when cold. They go to 40 or so when hot. Tpms is set at 40. If tire pressure drops to 34 when cold, there will be a 6* difference and warning will come on. That can't be what you meant.
06-06-2014, 11:29 PM | #5 | |
Rep 485
Get your psi straight, and reset TPMS while cold, then, there should be no issue until a cold morning of 40 deg f lowers psi 4#. |
06-14-2014, 05:58 PM | #6 |
Santa Fe Concorso
107
Rep 2,984
Remember air guages can be wildly inaccurate. I had an old one that read 12lbs high and drove me crazy with TPMS until I tried a different guage.
On another subject, I tried using old BMW TPMS sensors from 2008 on the 2013 X1 and they failed to work at all, giving an "Inactive" error. Dealer said they'd seen that before.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
06-14-2014, 09:46 PM | #7 |
Rep 485
Most dial gauges are pretty accurate. I bought several $3 cheap gauges that all read right.
Those that run the stick out can wear, and are tricky. Always use your own gauge, and reference ride and tire wear back to it. |
