      03-26-2014, 10:20 PM   #1
BoxsterPhil
Drives: Black 128
Regular or Premium Gas?
For everyday driving, do you use regular or premium gas? I use regular because premium is about 50 cents more in NYC. What do you use?
      03-26-2014, 10:29 PM   #2
squishy
Zimbabwe
153
Drives: 2014 Ford Mustang GT
Premium. As you're supposed to.
      03-26-2014, 10:30 PM   #3
Twix
Twix's Avatar
Drives: 2011 e91
Premium. Always. You lose power and economy using regular gas and also are running the risk of gumming up your injectors.
2011 E91
2016 M2 - Sold
2014 X1 - Sold
2002 Land Rover Discovery II - 3" lift & 33s
      03-26-2014, 10:50 PM   #4
jadnashuanh
Drives: 535iGT x-drive; i3 BEV
While at low speeds in the city, you might not notice the performance difference, because the computer must detune the vehicle a fair amount to keep from burning holes in the pistons or burning the valves up, it doesn't run as efficiently. But, it will continue to run without internal damage. Often, the cost per mile comes out about the same, and if you do get a chance to use the performance, it's there and not blocked if you've got premium in it. Note, some brands, regardless of the grade, skimp on the cleaner additives, on those that do provide them, there's more in the premium. THe end result over time is going to be lost if you need even one engine cleaning at the dealer. Use premium from one of the www.toptiergas.com suppliers, and you'll have a much lower chance of having those problems.
Last edited by jadnashuanh; 03-27-2014 at 06:10 PM.. Reason: fixed the link, sorry
      03-26-2014, 11:52 PM   #5
danielj
Drives: 2018 x2
50 cents a gallon is what, $6 a tank? Maybe $18 a month if you go through 3 tanks. If your budget is that tight then you bought the wrong vehicle.
X135i0.00
      03-27-2014, 12:16 AM   #6
Eric5273
Drives: 2014 BMW X1
My dad tried 87 octane in his Jaguar a couple of times and got engine knocking. I always use what is recommended by the manufacturer.
      03-27-2014, 06:48 AM   #7
x1-2012
x1-2012's Avatar
Drives: BMW X1 x28i
Originally Posted by jadnashuanh View Post
While at low speeds in the city, you might not notice the performance difference, because the computer must detune the vehicle a fair amount to keep from burning holes in the pistons or burning the valves up, it doesn't run as efficiently. But, it will continue to run without internal damage. Often, the cost per mile comes out about the same, and if you do get a chance to use the performance, it's there and not blocked if you've got premium in it. Note, some brands, regardless of the grade, skimp on the cleaner additives, on those that do provide them, there's more in the premium. THe end result over time is going to be lost if you need even one engine cleaning at the dealer. Use premium from one of the www.toptier.com suppliers, and you'll have a much lower chance of having those problems.
I fully agree .... However the said site www.toptier.com is not the good one.... Please return to us with the good web address,
Thanks!
      03-27-2014, 07:10 AM   #8
Gort
Klaatu Barada Nikto
Gort's Avatar
Drives: 2017 X3-35i
Thanks!
Its toptiergas.com
I believe that this is more of a "play for pay" endorsement than anything. Sunoco has highly regarded gasoline, but they won't pay to get on the list apparently.
Personally there is no way I would used Regular gas in these turbocharged engines.
      03-27-2014, 08:51 AM   #9
Red Bread
Drives: Smog machines
It's a good thing BMW pays for the OP's oil changes, or I assume he'd be using non synthetic or maple syrup.
X135i0.00
      03-27-2014, 09:14 AM   #10
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
According to the manual, 89 is the minimum octane rating. 91 is recommended. If you're putting in 87, you may be jeopardizing any warranty claims that arise from improper fuel.
As others have mentioned and we've experienced this personally when premium was non-existent post-Sandy, lower octane yields lower gas mileage and poor performance.
Come out to Long Island, there's only a $.30 difference between regular and premium!
2007 E92 328i 6MT-Space Gray/Black Dakota/Gray Poplar w/heated seats-PCD 4/27/07 (SOLD)
2009 E90 328i xDrive 6AT-Space Gray/Oyster Dakota/Dark Burl Walnut w/ZPP,ZCW,Xenons-ED 4/17/09 - Redelivery 5/30/09 (SOLD)
2014 E84 xDrive28i 8AT-Alpine White/Black Nevada/Silver Matte w/ZMV,ZLP,494 - DD 3/14/14 (SOLD)
      03-27-2014, 09:21 AM   #11
atomic
Drives: 2016 x3 x-line white
I used the 89 octane for one tank and it didn't perform as well. I wouldn't use less than 89 as the owners manuals states it will adjust for 89 but I don't think it will adjust for less than that.
      03-27-2014, 09:23 AM   #12
atomic
Maybe he is leasing. If I were leasing I wouldn't care what it does to the engine.
      03-27-2014, 09:29 AM   #13
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
FWIW, our CA told us that they put in 87 for that "free" full tank of gas they give you when you take delivery. That's why I'm not concerned with the 18.9 mpg achieved on the 1st tankful and it sort of explains it as well.
      03-27-2014, 09:33 AM   #14
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
That's why I would never purchase a BMW that comes off a lease and I advise the same to everyone who asks.
      03-27-2014, 09:36 AM   #15
Red Bread
I'd be ecstatic about 18.9 mpg!
Our city mileage is usually around 16.0 using 93 octane, but did manage a little over 26 on the last tank, with a trip to Austin.
A friend of mine is a mechanic who's worked for some racing teams in the EU and he uses 87 in anything on the highway because the lower loads and constant state running produce lower loads. In the city, you have higher loads, so running lower octane is worse than if you were doing all highway driving. I've never followed his lead, I just found the logic at least partially believable.
      03-27-2014, 09:40 AM   #16
STE92VE
STEVIL Empire
STE92VE's Avatar
Drives: Fast
I think that's pretty believable since most equipment runs best at a constant state.
      03-27-2014, 09:52 AM   #17
bluejay_el
bluejay_el's Avatar
Drives: 2014 BMW X1 xDrive 28i
it this a trick question?
      03-27-2014, 10:38 AM   #18
paradoxical3
Tuned so I do 93 and an e85 blend.
      03-27-2014, 10:45 AM   #19
tominavl
Keeping it Real
Drives: 2014 X Drive 2.8i Sport Line
When I took delivery last Fall, my dealer said: "use a good brand 87 octane." That's what I do. I love the car, and I don't drive it like I stole it. I'm satisfied. When I need extra power, it rises to the occasion. It's a well-designed little turbo motor. I had a Saab 2.0L turbo for 12 years and did the same thing and it never let me down. 160,000 miles of driving pleasure.
      03-27-2014, 03:23 PM   #20
Black Flagged
Black Flagged's Avatar
Drives: M2C
91 octane all the time, except when my kids or wife drives it. Then they will put 87 in it and tell me that they put the good stuff in, but I can tell the difference!
      03-27-2014, 07:43 PM   #21
GTony
Australia
28
Drives: 2015 X3 F25 XDrive 28i M Sport
My circumstances are much different with diesel. After P/U from Dealer drove 500Km's home and got 5.7L/100km's. Don't know what fuel they put in that comes with a full tank when buying new car.
My second fill up was Premium Diesel because we intend keeping for long time and only use Premium which is around 7 to 12cents a Litre more.
For my Service a year later my average to the dealer and back was 4.7, 4.8 and 4.9/100Km's. That's driving on Highway/Freeway with some speed limits to 110Kmh's an hour.
I do believe that Premium is much better for the engine and some more Km's/Mileage from a tank.
Sorry for the different comparisons/diesel comments, you will have to work out. Just offering my point on Regular v Premium.
      03-27-2014, 09:40 PM   #22
halfmoonclip
Drives: X1 28i
I'm skeptical that the turboed engine would run well on regular....
Moon
