02-15-2014, 06:53 PM | #1 |
Rep 302
Seeing 545is on the market cheap
Anyone noticed all the 545i are worth 10,000$ or less now . Are they worth buying past 100,000 miles and this old? I've drove many before it's a world difference in handling
02-15-2014, 07:05 PM | #2 |
Rep 150
Yeah..My understanding is most of the cheap ones have been poorly maintained and need lots of $$ to make right again. Same thing with lots of BMWs and Mercedes. Look at the price difference for W211 E Classses- sure you can pick one up under $10k, but plan on doing rear springs, motor mounts, brakes, tires, pollen filters, trans service, brake flush, and more. On a 2005 E320, thats about $5k worth of work..so is it really a bargain after all?
02-15-2014, 07:14 PM | #3 | |
Rep 302
02-15-2014, 08:21 PM | #5 | |
Rep 244
Overall, the car has been great and I did have to change all the things you mentioned except the brakes which wear down well (impressed)... I spent approx 2Gs over a course of 7 years of ownership... I think e-class is well worth the price given the advanced options offered... And it's quality build |
02-15-2014, 08:58 PM | #6 |
Rep 20
I had a 2004 545. Great car. I had 97k miles on mine when I got rid of it. The cost of ownership rather costly . I kept mine maintain and still expensive to repair. The motors on those are solid and last. Everything connected to it is a problem. Most bmw lose most if there value after 100k.
02-15-2014, 09:45 PM | #8 | |
Rep 302
02-15-2014, 10:06 PM | #9 |
Rep 20
My was under cpo warranty plus I biught the extended maintenance warrenty. After that ran out I found a coolant leak brakes all around and the tranny was slipping. They replace the tranny at 77k miles under warrenty. Coolant, brakes were going to run about 3500. They may of been 1 or 2 more things. BMW treats the v8 5series as 7 series maintenance wise. I will tell there are days I wish I still had it.
02-15-2014, 11:00 PM | #10 | |
Rep 150
02-16-2014, 01:23 AM | #11 |
Rep 354
02-16-2014, 02:11 AM | #12 |
Rep 302
02-16-2014, 08:51 AM | #13 |
Rep 20
Chad, the handling on the e60 with sport was amazing my e90 doesnt have sport. So I can't compare. This post has made me miss my e60. Chances are at 150k mile the coolant leak has been done. Have a trusted indy check the tranny as that was mine major problem. Diy on those are rather simple. Check out The e60 forums might have to google that. They will give you the lastest on ownership. You can go wrong with either.
02-16-2014, 02:35 PM | #14 |
Rep 150
True, if you can even do basic DIY most of the issues and maintenance on these cars won't be nearly as bad cost wise. We also own an older Range Rover and its the same way- don't buy one unless you work on it yourself.
02-16-2014, 04:42 PM | #15 |
Rep 791
Drives: 2011 550xi
I've heard a lot will have massive oil consumption issues due to warn piston rings. So the seller will throw some thick oil in and try to ditch it.
I looked at a lot of 545's before my 335, I prefer turbo torque over V8 madness. That and the 5 series is too laid back for me, I'm a younger guy, I like my cars aggressive.
2017 Nitro Blue Ford Focus RS 2008 Sparkling Grey Metallic 135i 6MT - JB4 G5 - MHD Race BEF - N54Tuning DP's - ER Chargepipe/w HKS SSQV - Coolingmist Progressive Meth - MMP Hot Side Inlets - AFE Exhaust - Seconday Cat Delete - AMS FMIC - BMS Catch Can - Rob Beck PCV - LUX 160 AE |
02-16-2014, 11:48 PM | #16 | |
Rep 302
02-16-2014, 11:51 PM | #17 | |
Rep 302
02-17-2014, 04:27 AM | #18 |
Rep 14,829
Does anybody believe that people give things away, for less than they're worth? Some markets are pretty efficient, such as eBay, and used cars. And due to efficiency, sometimes, things are cheap. Like a USB/aux adapter for a 2k7 to be used for iPods, $3 to $5. there are other things that are not cheap, like 7 series that cost 12k, or 5 series that cost 10k. These are 8 cyl vehicles whose repairs are known, and expensive. i.e the previous owner is not giving anything away when you see a price tag in the 10-20k range. The repairs are already factored in.
