      06-15-2013, 08:37 PM   #1
donsbabybeamer
Drives: 2014 x1
Can this be programmed re: folding mirrors
I would like the side view mirrors to fold in when I lock my X1 and fold out when I unlock my X1 instead of having to push the button on the drivers door to fold in and out.
      06-15-2013, 09:21 PM   #2
X1 Trojan
Go Dodgers?
X1 Trojan's Avatar
93
Drives: '13 BSM X1 xdrive35i Msport
someone with coding experience could maybe do this--never seen it but i dont think it'd be that hard (not an expert at all on coding tho)
      06-17-2013, 12:55 AM   #3
GreatStarSe7en
GreatStarSe7en's Avatar
Drives: 2013 X1 xDrive28i Sport Line
yes, it can be programmed. go to **************, there are a lot more that's programmable.
      06-17-2013, 06:10 AM   #4
donsbabybeamer
Drives: 2014 x1
Not sure if ************* is meant to be funny or not. If it is than it is not very funny, if not what does ************* mean?
      06-17-2013, 07:09 AM   #5
skylineguv
Drives: 2015 Macan Turbo, Jet Black
It's just a link to a website that's automatically removed by this forum......I doubt anything funny was intended.
      06-17-2013, 01:29 PM   #6
vbbuilt
Drives: x28i
Perhaps a PM between the two of you will solve that problem?
      06-17-2013, 05:39 PM   #7
widdyshek
Drives: x1 2.8
yes, it is possible thru program(both thru comfort access or thru the remote). I got mine done from a local guy with a small fee. He also added auto unlock all doors when shut off which I like a lot.
      06-17-2013, 07:04 PM   #8
Teutonic
Teutonic's Avatar
I didn't know you can do that with the X1. Skylineguv, did you have it done?
      06-17-2013, 08:31 PM   #9
Lynxx
Drives: Nissan 300ZX now, X1 soon
Great idea. Now why didn't BMW think of it? Let's see. . .
You want the power folding mirrors switch to operate as originally intended PLUS you want to add the following two functional abilities:
(1) to automatically rotate the power folding mirrors outwards when the ignition is turned on and (2) to automatically rotate the power mirrors inwards when the ignition switch is turned off? Correct?
It sounds doable but there's a problem with (2) above. Once the ignition is turned off, there won't be any electrical current being delivered to the mirrors to rotate them. Some sort of timer will be needed to provide current to the power folding mirrors so that they can rotate after the ignition is turned off. About 5 seconds of current will be needed to accomplish this.
I'm not an electrical engineer but I think there might be some complexity involved in order to implement this feature. Especially if there isn't already a timer in the ignition-off circuit. And you'd want to dovetail this mod into the electrical system without adversely affecting the rest of the electrical system. Before any existing wires are cut and new wires are soldered in, make sure you find an electrical engineer with automotive experience.
      06-17-2013, 09:13 PM   #10
danielj
Drives: 2018 x2
Since you can roll the windows down using the key fob with the ignition off, there is already power flowing within the vehicle once turned off. And guess what, you can power fold the mirrors with the interior button, ignition off! The OP just wants them to activate with the key fob, like the Volvo XC as an example.
OP, surely this can be done via coding. What you're asking for is common on newer Euro vehicles. Hopefully someone chimes in with the answer.
      06-17-2013, 09:25 PM   #11
Teutonic
Teutonic's Avatar
OK, Guys, I am confused,
I can not fold in any way my mirrors except by using my hand. You can fold them from the interior?
Should I understand that this is possible only on 2013 models and up?
Because mine is a 2012 with the larger mirrors. Please let me know.
If you have the option to fold them from inside it makes sense for you, but mine don't fold from inside (except I am missing something....)
      06-17-2013, 10:00 PM   #12
danielj
Drives: 2018 x2
US 13+ models have a button on the drivers door, below the adjuster and next to the L/R switch to power fold the mirrors in or out. Not sure about Canadian spec models.
      06-18-2013, 01:08 AM   #13
luvmyone
Drives: 2017 M240 RWD 6 speed
Comfort access?
Do you have comfort access?
I believe the power folding mirrors is grouped into comfort access in Canada
M240 on order.RWD 6spd.
      06-18-2013, 03:54 AM   #14
donsbabybeamer
Drives: 2014 x1
Yes I have comfort access. MY 2010 ML350 had this function, lock the car with the remote the mirrors folded in, unlock with the remote the mirrors folded out. You could turn this feature on and off through the electronic on board settings.
I feel as if my 3 year newer BMW has taken a step back in this function. The worst part of the BMW set up is that when you start to drive the auto fold out feature (which it does have) doesn't kick in till you reach 25 miles an hour. I kinda like to see if a car is pulling along side of me before I pull out into it's path !
      06-18-2013, 06:47 AM   #15
skylineguv
Just like other BMW's with power folding mirrors, you should be able to have them coded to fold/unfold via the keyfob. From a coding standpoint, I doubt it'd be much different than E9x chassis vehicles, but I don't honestly know anyone that's checked thus far.
      06-18-2013, 08:37 AM   #16
donsbabybeamer
Drives: 2014 x1
Can the dealership do this coding?
      06-18-2013, 11:55 AM   #17
Twix
Twix's Avatar
Drives: 2011 e91
Yes. Typically BMW gives you 12 free coding session. After that you'll be paying for any coding. So go in with a list, get it done for free.
      06-18-2013, 01:40 PM   #18
Teutonic
Teutonic's Avatar
Good info, thank you.
So it can be done on MY 2012?
      06-18-2013, 01:44 PM   #19
Twix
Twix's Avatar
Drives: 2011 e91
12 was a typo, I meant 1.
      06-18-2013, 01:52 PM   #20
Teutonic
Teutonic's Avatar
well, this change everything, think twice before you pull the trigger.
Still.... does it work for MY 2012?
      06-18-2013, 02:39 PM   #21
donsbabybeamer
Drives: 2014 x1
Greta info on the dealer doing 12 coding's free. Is this up to the individual dealer or is this a BMW policy?
I already have the ASS coded to last position, what other possible coding changes are there?
      06-18-2013, 03:26 PM   #22
Michael Schott
Drives: 2017 VW GTI Sport
If you don't have the Premium Package you don't have power folding mirrors. It may also be part of the Comfort Access package as mentioned above.
