      12-24-2012, 02:14 PM   #1
Bill B.
Bill B.'s Avatar
Drives: '18 M2, '13 X135i '15 S1000R
Question Comfort Access Fob Hole
Ok, this is strange. Our comfort access fob's work fine, until I try to start the car with the fob in the slot. Nothing. If I take the fob out of the slot, it starts just fine.
The slot holds onto the fob and releases it as I would expect...
      12-24-2012, 03:31 PM   #2
voerman
Member
Drives: '19 530e
Try pushing it in farther, worked for me.
By the way I am also in Cary.
Lou
      12-27-2012, 05:52 PM   #3
Bill B.
Bill B.'s Avatar
Lou
I'll give it a try. The wife's fob works fine, it's just mine that doesn't work in the slot.
Lou, do you have a Blue X1? That's the only other X1 I've seen on the road.
      12-28-2012, 08:44 AM   #4
mullini
Mullini
mullini's Avatar
Drives: 2017 i3 BEV
I'm confused - if you have Comfort Access, which is basically keyless ignition, why are you putting the key in the slot? I don't even know why the slot is there on Comfort Access models - I suppose it is just a part of the BMW build configuration. The manual says that the Comfort Access key cannot be charged by inserting in the slot. Instead, there's a battery that has to be replaced periodically. Such is the case with the key for my Lexus IS250, a 2006 model.
My key stays in my pocket....
      12-28-2012, 09:26 AM   #5
backpackerx
Drives: 2013 BMW 328ix
Usually the slot is only there so you can insert it to start the car if the fob battery dies. It doesn't need to be in there any other time.
      12-28-2012, 10:44 AM   #6
HotRodW
HotRodW's Avatar
Drives: 2013 X1 xDrive28i M Sport
The key fobs are rechargeable. They charge automatically when docked.
      12-28-2012, 03:10 PM   #7
Bill B.
Bill B.'s Avatar
Right. I was just checking to make the feature worked (for when the battery in the fob does die.)
      12-28-2012, 03:11 PM   #8
Bill B.
Bill B.'s Avatar
Only for non-CA fobs. CA fobs have a replaceable battery.
      12-29-2012, 08:18 AM   #9
mullini
Mullini
mullini's Avatar
Drives: 2017 i3 BEV
Ah that makes sense. On my Lexus IS250, in that event, one is supposed to pry the push button cover off and use the "valet key" that pulls out of the fob to start the car. I never have had a reason to do that, however.
I suppose this is covered in the X1 manual but I don't recall reading that. And I got a really rushed demo when I picked up my X1...
      12-29-2012, 03:01 PM   #10
36Joules
Drives: 2024 X5 50e, 2018 S3, TeslaM3P
Car Wash
Also used to keep the car in Neutral in a car wash, see owners manual p 259.
      12-30-2012, 11:09 PM   #11
BMWrules7
Drives: 2015, 740 LdX, Alpine White
That sucks you got a rushed demo. I think the sales guys get paid for the demo.
