Go Back   XBimmers | BMW X1 Forum > BIMMERPOST Universal Forums > General Automotive (non-BMW) Talk + Photos/Videos
      04-10-2024, 05:20 PM   #1
chassis
chassis's Avatar
6692
Drives: 9Y0 Cayenne S
2025 4Runner announced!
Long awaited by 4Runner fans everywhere. Arguably the best vehicle ever designed, manufactured and sold.
https://pressroom.toyota.com/2025-to...eady-heritage/
2 powertrains: 2.4L 4-cylinder ICE and 2.4L 4-cylinder mild hybrid, both with 8-speed transmission.
jesm207.50
LDT1620.50
      04-10-2024, 05:36 PM   #2
ash_schwin
ash_schwin's Avatar
394
Drives: AW G80 6MT
2023 BMW M3  [5.67]
I love the new body style....very much past due by this point. We have one at home and it is a bulletproof reliability vehicle.
chassis6692.00
jesm207.50
      04-10-2024, 06:19 PM   #3
gonzo
gonzo's Avatar
Drives: as many as possible
As far as looks go, not bad.
Except for the snorkel.
Stop it.
I'm looking at you too, moist pea gravel roaming Defenders.
Crazy Diamond
chassis6692.00
      04-10-2024, 06:27 PM   #4
RM7
RM7's Avatar
2906
Drives: Camaro SS 1LE
I was pretty sure it would use the new Tacoma drivetrains. Not surprised.
chassis6692.00
      04-10-2024, 06:46 PM   #5
Burrcold
Drives: 2024 M3 Comp xDrive
Toyota is cashing in on all these new models! Looks good, but more importantly, it looks like a 4Runner!
chassis6692.00
jesm207.50
      04-10-2024, 06:46 PM   #6
MADBMWX5MC
MADBMWX5MC's Avatar
1044
Drives: 2023 BMW X5MC
I hope these two bring enough power to this new beast...
"Standard i-FORCE turbocharged 2.4-liter four-cylinder engine produces 278 horsepower, 317 lb.-ft. of torque"
"Available i-FORCE MAX hybrid powertrain produces up to 326 horsepower, 465 lb.-ft. of torque"
chassis6692.00
      04-10-2024, 07:32 PM   #7
Donatello.
How's My Driving?
Donatello.'s Avatar
1109
Drives: Hellcat & Miata
Are you drunk?
2018 Charger Hellcat
2019 Miata 30th Anniversary
2021 CX-5 Signature
2009 Mazda6
Appreciate 8
chassis6692.00
RM72906.00
mjj223.50
LDT1620.50
VR1641.00
      04-10-2024, 07:34 PM   #8
Donatello.
How's My Driving?
Donatello.'s Avatar
1109
Throw 1500 HP at it and/or run a Baja race & see if it's bulletproof lol
chassis6692.00
      04-10-2024, 09:34 PM   #9
Sedoy
Drives: F10
Can anyone explain to me what's the point of Toyota's 2.4L turbo i-FORCE MAX hybrid powertrain? The gas consumption is the same as the non-hybrid BMW i6 B58 in X5 or even X7, but slower, more complicated, takes more space, can't be plugged-in and requires premium gas. I do get old high MPG and slow 2.5L hybrids, but new i-FORCE MAX hybrid striggle to deliver any MPG improvements compared BMW I6s. Does this make any sense or we are just spoiled by awesome BMW powertrains? Maybe emissions, CAFE?
BTW, love the styling Tacoma/4Runner styling and physical controls.
chassis6692.00
      04-10-2024, 10:40 PM   #10
335i54n
Drives: e90 335i, e39 m5
toyota hybrid philosophy is different with the trucks. the hybrid is the power up motor, not for more mpg (get a prius) but for more power. they focus more on qdr and the battery packs are meant to be cheaper and ez replace down the line. they may be less efficient (its a truck/work vs passenger) but 10x more durable, it be nice if they adopted 8hp
chassis6692.00
      04-10-2024, 11:07 PM   #11
RM7
RM7's Avatar
2906
The point is torque. It's exactly what the high-revving V6 engines lacked.
I drove a 3.slow 4 runner extensively. Then the higher HP V6 engines starting coming along, much higher compression, much higher rev limits, etc. These were decent for a few years, especially when turbo tech was still extremely laggy and required revving up to 3K to build up any significant power. V8s were kind of the go-to back then, but they are big in the engine bay, heavy and take a lot of gas...at all times. Even as they pumped those V6s higher and higher, up to around 350 in some cars, they still never had the shove of a V8 or modern turbo car. The torque curve tells you all you need to know...it has to rev to 7K or whatever for peak and it's not flat. Now modern turbo engines make full torque around 1300-1500rpm, all the way up through their rev-range. The one in my ZR2 makes 430lb/ft of torque. This also gives cars a good shove down low, since they are making all that torque way WAY before the top of the rev range. Turbo lag with turbos now attached directly to the block where the exhaust manifold basically houses the turbine section, often with twin scrolls and other arrangements, is a thing of the past. Trans tunes and pedal response are different reasons why cars aren't "faster", but having a "normal" and "sport" setting allows them to get the mileage for the testing in the normal setting, and then that better response in the "sport", showing that there's no significant turbo lag.
Hybrid is another way to add torque, especially from 0mph. Again, these modern turbos make full torque at ridiculously low rpm compared to old 90s tech and before, but hybrid brings that to the next level.
Torque.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
nick37531032.00
chassis6692.00
x622986.00
      04-11-2024, 04:05 AM   #12
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
Yeah, thanks, but I'll keep my Gen 6 Bronco with its 2.3L EcoBoost 300 HP and 325 pounds of torque running through a manual transmission.
And the top comes off with just 8 bolts.
It's just a more interesting drive.
chassis6692.00
      04-11-2024, 07:17 AM   #13
BlkGS
BlkGS's Avatar
1402
Drives: BMW X5 M50i
Looks killer, but I don't get how it's gonna work out with the Land Cruiser being like, basically the same. Same motors, I think they're the same size, just seems like they are basically the same vehicle.
chassis6692.00
      04-11-2024, 08:23 AM   #14
unluky
unluky's Avatar
7577
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
Finally - maybe the last ones will stop being $50,000 10 years old with 80K on the clock. LMAO!
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
chassis6692.00
      04-11-2024, 09:00 AM   #15
W///
W///'s Avatar
7532
Drives: F82GTS, E36/E92M3, Z4M
Originally Posted by Donatello. View Post
Are you drunk?
Obviously he's not talking about driving dynamics, but in terms of reliability? All day long.
I had a 7 owner 1997 4Runner with over 300k miles and had been in a few accidents according to Carfax. As with all cars I buy, I go ahead and change all the fluids. Turns out the radiator and trans cooler is one unit and the fluids had mixed. When I drained the trans fluid, it looked like strawberry milkshake and I thought this trans was for sure dead.
Changed radiator (under $100), added new trans fluid and drove the car for years before I sold it for more or less same price.
So yea, I have a soft spot for Toyota trucks/SUVs.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT
08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT
07 E85 Z4M Roadster, Alpine White/Red, 6MT
99 E36 M3, Techno Violet/Dove Grey, 6MT
jesm207.50
chassis6692.00
      04-11-2024, 09:29 AM   #16
DFW_M
Drives: Macan GTS
Because it is made for that and intended to be used that way?
chassis6692.00
      04-11-2024, 09:31 AM   #17
DFW_M
Drives: Macan GTS
until it hits 40k miles and starts falling apart...just like my daughter's Christmas tree dash board 2019 Wrangler with 51k miles on it...
chassis6692.00
      04-11-2024, 09:35 AM   #18
Efthreeoh
Wait. Did Stellantis buy FoMoCo?
chassis6692.00
      04-11-2024, 03:40 PM   #19
Donatello.
How's My Driving?
Donatello.'s Avatar
1109
Because we're car nuts?
chassis6692.00
      04-11-2024, 05:32 PM   #20
chassis
chassis's Avatar
6692
Excellent 4Runner ownership story. And not uncommon.
      04-12-2024, 12:01 PM   #21
86Zed
Get off my lawn
86Zed's Avatar
Drives: 6MT
2022 BMW X3 M40i  [10.00]
2011 BMW 135i  [10.00]
2007 BMW Z4M Coupe  [10.00]
1991 BMW 318is  [10.00]
The B58 is a monster of an engine with multiple personalities. We regularly average 28mpg on a tank and can simultaneously light the tires up with real speed in our X3.
Big fan of the rugged looks and reliability of these Toyotas, will be watching intently to see how the gearbox and infotainment setup are reviewed. A 3rd row would be nice in my life
chassis6692.00
      04-12-2024, 07:08 PM   #22
DFW_M
Drives: Macan GTS
Ah, I forgot, the Ford reliability record is Stellar!
What foes Fird stand for again??
chassis6692.00
