      11-14-2021, 08:58 AM   #1
polarbmw
Drives: e84 x1
Engine Malfunction - Reduced Power
Friday driving home from work and sudden engine malfunction reduced power message came up on iDrive of 2013 xdrive28i. Engine shaking and could smell gasoline. Limped home and parked. Disconnected battery. Smelled like gas from exhaust. P0304 code misfire cylinder 4. On Saturday, took out spark plug, gasoline on plug, replaced plug and coil. Started car and same issues as above but a lot of white smoke coming from exhaust so I turned off ignition and disconnected battery again. Can you please help me on what else could be the problem?
      11-21-2021, 12:42 PM   #2
aloyouis
Drives: 2013 X1 x28 MSport
White smoke?
Head gasket? Check your coolant level.
      11-21-2021, 05:47 PM   #3
05X3lover
Drives: '15 Dark Gray X1 AWD
Head gasket fail does seem likely if there's a lot of white smoke. I wouldn't run the motor until you figure out if that's the issue or not.
      11-22-2021, 01:55 PM   #4
Gamb1t
Gamb1t's Avatar
You should check the other plugs and coils too. Are there any oil residue in the coolant reservoir?
