      07-07-2021, 05:02 PM   #1
Garrige
Drives: X1 e84 , e91
Help with hpfp error . E84 , 2.3D (4560)
Hey guys !
I am not exactly fluent in English , especially in all this technical terms but ill try .
I bough E84 2011 2,3 D. My wife drowe it for a week and then going on the highway she had put full throttle down and got Engine Fault ( fuel engine power no longer available.) ( 4560 code)
So basically High pressure fuel pump died it let metal shavings in nozzle and whole system .
After repair , car seemed to work fine but when i tried to put peddle to the metal its again giving us Fuel pressure fault .
Nozzles where restored , HPFP was restored , New Fuel pressure sensor , new Rail pressure sensor, new rail pressure regulator , new HPFP sensor , New fuel tank , all tubes where cleaned out , new fuel filter was installed , Pump in tank was also cleaned out . EKps Fuel pump control unit is replaced and coded ( e61)
My friend/ mechanic thinks the problem can be in EKPS ecu ( , Rheingold Bmw diagnostic shows pressure of 3.9-4.2 is it normal ? Why does specificated and real revolutions in tank do not match , and why dose it give 4 bar pressure.
If anyone got any clues it will be huge help!
Again sorry for broken English
      03-16-2022, 08:34 PM   #2
yogisunardi
Drives: BMW E70
Originally Posted by Garrige View Post
Hey guys !
Hi Garrige,
did you solve the problem?
Would you tell me, what parts exactly made the problem?
Cheers
Yogi
