      08-31-2019, 10:57 PM   #1
d0ctorj3kyll
Australia
Drives: 2019 F82 M4 Comp
2012 E84 23d hardwiring Cellink Neo battery - help?!
Hi all
Having a lot of trouble locating a switched / ACC fuse in my 2012 E84 X1 23d to install the add-a-fuse for my new Cellink Neo battery pack.
All the fuses I have tried so far are either constant power, not connected at all or not instant-off accessory fuses (i.e. they stay powered for a stretch of time after the engine is turned off).
Battery is designed to typically draw 9A current up to a max of 13.5A, and Cellink supply it with 20A fuses so I'm looking for an empty 20A fuse slot ideally.
Previously had a Blackvue Power Magic Pro attached to fuse 10 by the guy who installed the camera. Fuse 10 is for heated/electric seats which I did not option and is apparently an ACC fuse as the PMP worked fine.
I have tried using other higher-rated fuses assigned to the seating systems but they all appear to be constant power slots which I don't understand.
Help would be sincerely appreciated!
      09-04-2019, 09:14 PM   #2
kringer2
Drives: 2014 X1 28i xdrive
Have you tried Fuse NO 8? On my car its the power port and 20 amps. Only on when the car is on.
